masl999
  • in reply to: Login Page #16187
    masl999
    Hi Mikhail, i see that this worked for version v5, now on v6 is it possible to change the landing page, text, images?
    i found out you made it on the dll (ScadaWeb.dll), so we cannot change it anymore?
    will you add a paid option for us to change it?
    ty
    in reply to: Update from 5.8.3 to V6 #13923
    masl999
    by any chance is it possible to use a V5 SCADA with Rapid Gate to connect to a V6 ?
    if I upgrade from V5 (delete all) and install new V6 (latest, windows), the computer code and the license remains the same?
    on V6 is it possible to change the layout of the landing page (main page) as it was on V5?
    in reply to: Update from 5.8.3 to V6 #13922
    masl999
    Hi, the convert V5 to V6 worked with some issues, one that i am having problem is that the unit of the converted v6 has changed:
    V5= <UnitID>67</UnitID>
    V6= <UnitID>1</UnitID>
    Any hint to fix it or to scan manually each variable?
    <InCnl>
    <CnlNum>4297</CnlNum>
    <Active>true</Active>
    <Name>TP_CxPermeado_2017</Name>
    <CnlTypeID>3</CnlTypeID>
    <ObjNum>3</ObjNum>
    <KPNum>51</KPNum>
    <Signal xsi:nil=”true” />
    <FormulaUsed>true</FormulaUsed>
    <Formula>(((Val(4288)/100)+0.15))>5 ? 5:(((Val(4288)/100)+0.15))</Formula>
    <Averaging>false</Averaging>
    <ParamID xsi:nil=”true” />
    <FormatID>2</FormatID>
    <UnitID>67</UnitID>
    <CtrlCnlNum xsi:nil=”true” />
    <EvEnabled>false</EvEnabled>
    <EvSound>false</EvSound>
    <EvOnChange>false</EvOnChange>
    <EvOnUndef>false</EvOnUndef>
    <LimLowCrash xsi:nil=”true” />
    <LimLow xsi:nil=”true” />
    <LimHigh xsi:nil=”true” />
    <LimHighCrash xsi:nil=”true” />
    </InCnl>
    <Cnl>
    <DataTypeID xsi:nil=”true” />
    <DataLen xsi:nil=”true” />
    <ObjNum>3</ObjNum>
    <DeviceNum>51</DeviceNum>
    <TagNum xsi:nil=”true” />
    <TagCode />
    <FormulaEnabled>true</FormulaEnabled>
    <InFormula>(((Val(4288)/100)+0.15))>5 ? 5:(((Val(4288)/100)+0.15))</InFormula>
    <OutFormula />
    <FormatID>4</FormatID>
    <OutFormatID xsi:nil=”true” />
    <QuantityID xsi:nil=”true” />
    <UnitID>1</UnitID>
    <LimID xsi:nil=”true” />
    <ArchiveMask xsi:nil=”true” />
    <EventMask xsi:nil=”true” />
    </Cnl>
    in reply to: Error updating current data at webstation Scheme #7490
    masl999
    I belive i found the error; formula dividing by Zero when asked to display at the screen
    in reply to: Error updating current data at webstation Scheme #7486
    masl999
    I have a similar error, trying to open a page show the error “Error updating scheme data”.
    The RapidScada was working fine for about a year without a issue and started this. Already tried to delete DAT files and a few other things and did not work.
    Specifications:
    Windows 2008 Server
    .Net Framework 4.8
    Administrator 5.5.2.1
    Communicator 5.2.1.0
    Server 5.1.4.0
    https://ibb.co/8YfGHY2
    https://ibb.co/1dmbvLk
    https://ibb.co/1fhc0XG
    https://ibb.co/HqsCqXr
    • This reply was modified 5 years, 11 months ago by masl999.
