skk2019
  • in reply to: User input through Scheme #5847
    skk2019
    Hi Mikhail,
    Thanks for your reply. I managed to make it work! I was getting the input channel wrong. Thanks 🙂
    in reply to: User input through Scheme #5838
    skk2019
    in reply to: Viewing communication log #5690
    skk2019
    yes, adding that feature would really be helpful to check the errors. Right now I got errors during the night but when I want to check what caused those errors I have no log. Hence, the error logging feature will be really helpful.
    Thanks 🙂
    • This reply was modified 7 years, 3 months ago by skk2019.
    in reply to: Set alarm for event #5634
    skk2019
    Thanks for the reply. I managed to install and add the plugin in the ScadaSeverCrtl.exe. However, the alarm still plays the old sound file and not the one configured at in the Modules.
    Also, my initial problem about the alarm, that it should only play after a certain limit and not below a certain limit has not been solved. Eg. alarm should play when channel value is 1 but should but play if it goes to 0. Can this be achieved?
    Thanks.
