battassini
ParticipantDear.
Below the hold register address in the I / O module that I use.
Do I need to trigger a digital output D01?battassini
ParticipantDear.
For I use C# for writing formulas. The local is:
Once you have programmed the formula to use it just insert in output channel Formula:
battassini
ParticipantHello.
Thanks for the answer but I already tried both binary and standart options and also tested sending 0 or 1.
Thanks.
battassini
ParticipantDear.
For use formula c# first I programming formula in Administrator option Dictionaries – Formula.
After I Used the created Formula in field Formula Output Channels in Administrator?Thanks.
battassini
ParticipantPlease always I run application on the rapid Scada I have to execute all the steps of the video First RUN?
https://www.youtube.com/watch?v=0d_uDvLT-NM&index=4&list=PLeyJvzEKXs5D3ELQ7LLdpvCRQbQntgtkQ
And if I disconnect PC where it is running application and connect again I have to start everything manually?
battassini
ParticipantDear.
Thank you for your quick response.
I have a problem.
The Administrator is not opening when I run it? Not open?
My windows 8.1.Thanks.
