Programming
  • #5131
    battassini
    Dear.
    Please:
    1) Why kindly how do I enter numeric data or text type in the rapid scada example textbox in other platforms? Read bar code too?
    2) Is there any script language to programming events or routines or other logic associated with the tags?
    Thanks.
    • This topic was modified 7 years, 7 months ago by Mikhail.
    #5133
    If you need to send command to a device, you should create an output channel. See the default configuration, for example.
    1. You can use C# for writing formulas.
    2. Automatic Control Module allows to send commands on different conditions.
    #5139
    battassini
    Dear.
    For use formula c# first I programming formula in Administrator option Dictionaries – Formula.
    After I Used the created Formula in field Formula Output Channels in Administrator?
    Thanks.
    #5144
    I don’t understand the question, sorry.
    #5146
    battassini
    Dear.
    For I use C# for writing formulas. The local is:
    https://ibb.co/fGHtBrY
    Once you have programmed the formula to use it just insert in output channel Formula:
    https://ibb.co/m5hTS6x
    #5153
    1. Define a function in the Formulas table.
    2. Use the function in the Formula field of a channel.
