bragofsky
Meanwhile I was able to do it only in notification plugin.
Thanks!
Regards
This reply was modified 6 years, 3 months ago by
bragofsky.
bragofsky
ParticipantUPDATE: I already try to uncheck “Event on Change” without success.
Regards
bragofsky
ParticipantHere it is,
System.IO.IOException: An exception has been thrown when reading the stream. —> System.ServiceModel.CommunicationException: The maximum message size quota for incoming messages (10485760) has been exceeded. To increase the quota, use the MaxReceivedMessageSize property on the appropriate binding element. —> System.ServiceModel.QuotaExceededException: The maximum message size quota for incoming messages (10485760) has been exceeded. To increase the quota, use the MaxReceivedMessageSize property on the appropriate binding element.
It seems to be related with file size, probably the big interface background images.
Regards
bragofsky
ParticipantUPDATE: This only happens if “interface” option is checked.
So, for my propose “configuration database” is enough but i’m curious about what “interface” stands for.
Regards
bragofsky
ParticipantHello,
I have 8 locations each one with 2 tipes of events, power distribuition and HVAC. In ballon pop-up I show the number of events of each type, and the idea is to have the a “show details” above the number of events, linked to the proper page.
bragofsky
ParticipantSince I download a very small map, only for my area, the server run’s very smooth with 1% of cpu effort
bragofsky
ParticipantWhat do you mean with heavy?
bragofsky
ParticipantHello Mikhail, thanks for you reply,
I took the easiest way to have a tile server working,
Fist I install docker in a centos VM, then get a tile server turn key container, run it on centos vm, imported maps to database and voilá…. tile server working.
bragofsky
ParticipantLike a charm again… thanks Manjey73 and Mikhail.
Have a nice weekend
bragofsky
ParticipantThanks Mikhail,
Works like a charm but I’m limited to 100 symbols in formula input. Is there a way to add a range of input channels inside the OR gate formula?
Another question, how can I change the value of an input? with a NOR?
Regards
bragofsky
ParticipantHello,
I have another issue
I need to create a input to Station status to be showed in map, this input should behave like a or gate, my problem is with a OR formula in input channel, I can only put 2 inputs, when I put the third webstation stop’s working. I need to monitor 22 input’s to get the station status.
The formula i’m using is “OR(Val(1001), Val(1002), Val(1003))” but server returns a error saying that OR cannot deal with 3 variables.
bragofsky
ParticipantHello Mikhail, yes, is it possible?
bragofsky
ParticipantHello, I have the same issue,
How can I disable the auto log-out?
Here is an example of the log,
2019-02-07 17:38:50 <NAV-SMC-CO><DefaultAppPool><ACT> Connect to SCADA-Server “localhost”
2019-02-07 17:38:55 <NAV-SMC-CO><DefaultAppPool><ACT> Refresh the tables of the configuration database
2019-02-07 17:38:55 <NAV-SMC-CO><DefaultAppPool><ACT> Fill input channels properties
2019-02-07 17:38:55 <NAV-SMC-CO><DefaultAppPool><ACT> Fill output channels properties
2019-02-07 17:38:55 <NAV-SMC-CO><DefaultAppPool><ACT> Fill input channel statuses properties
2019-02-08 04:19:12 <NAV-SMC-CO><DefaultAppPool><ACT> Logout: admin. IP address: ::1
2019-02-08 04:19:12 <NAV-SMC-CO><DefaultAppPool><ACT> User information has been removed. IP address: ::1. Session: ak1o4gxfw0ssrl5jqmf3kw2i
2019-02-08 04:19:12 <NAV-SMC-CO><DefaultAppPool><ACT> Application shutdownbragofsky
Participantmanjev73, thanks!
bragofsky
ParticipantHello again, I already managed to edit formula table and it works great.
For a logical AND, is the same?
