eamonng94
  • in reply to: Random Number Generator #3722
    eamonng94
    Solved the seeding issue by removing the randomizer from the time loop, looks something like this:
    Random random = new Random();
    public double GetRandomNumber(double minimum, double maximum)
       return random.NextDouble() * (maximum - minimum) + minimum;
    • This reply was modified 8 years, 6 months ago by eamonng94.
    in reply to: Random Number Generator #3719
    eamonng94
    Hi Mikhail,
    this is the formula i have inputted into the formulas tab:
    However one problem i have found is that the numbers are coming from the same seed, so if i call a random number between the same values on two different input channels, it outputs the same number. Is there any way of implementing a formula, which for every instance of the source code, generates its own set of random numbers, different to that of another channel?
    in reply to: Reading Output Channel Values on Input Channels #3699
    eamonng94
    This is now sorted.
