jacklondon
Viewing 5 posts - 31 through 35 (of 35 total)
  • in reply to: Using the new basic scheme components #3732
    jacklondon
    Hi Mikhail,
    1. Updated ScadaSchemeCommon.dll. Unblocked it. All other DLLs were already OK. (Still no access to new scheme components!)
    2. Rapid Scada is set to default English (en-GB).
    2. Windows version is 10 Creators (ENT) Version 1703, Build Number 15063.1088.
    • This reply was modified 8 years, 6 months ago by jacklondon.
    in reply to: Using the new basic scheme components #3720
    jacklondon
    Hmmm,
    i got an error in the log file of the scheme editor.
    2018-05-17 12:54:40 <xxx><xxx><ACT> Load components from files
    2018-05-17 12:54:40 <xxx><xxx><EXC> Error loading components from files:
    System.NullReferenceException: Object reference not set to an instance of an object.
    at Scada.Web.Plugins.PlgSchBasicCompSpec.Init()
    at Scada.Scheme.CompManager.LoadCompFromFiles()
    in reply to: No library found for component #3577
    jacklondon
    Where do we activate the new components plugin?
    • This reply was modified 8 years, 7 months ago by jacklondon.
    in reply to: Source Code KpOpc.dll #3538
    jacklondon
    Awesome Job!!!
    in reply to: Distinct ports on the same device #3537
    jacklondon
    Thank you very much Mikhail!
