catcute
Viewing 15 posts - 1 through 15 (of 19 total)
  • in reply to: Rapid Scada Update and license key #4139
    catcute
    Because server has run for serveral days, The log file was filled with new data. I can not see the time when problem happen.
    in reply to: Rapid Scada Update and license key #4132
    catcute
    It look like problem from Automatic Control Module, after I remove this module, problem not happen again. Althought I’ve not setting for this module yet.
    in reply to: Display and Set the String Value for tag #4129
    catcute
    Hi, thanks, I will try fisrt!
    in reply to: Rapid Scada Update and license key #4128
    catcute
    Do you use Automatic Control module?
    –> yes, I use Automatic Control module and update to last version.
    I try the same config on another computer, it run with no problem. But when I run this config on Cloud VPS windows, the problem happen.
    in reply to: Rapid Scada Update and license key #4121
    catcute
    Yes, I updated to last version 5.1.0.4 but the same problem.
    in reply to: Display and Set the String Value for tag #4120
    catcute
    Hi, command type of output channel change to binary. Error of Scada server as below:
    2018-08-11 08:08:41 <HN3521><SYSTEM><ACT> Users are read from the configuration database
    2018-08-11 08:08:41 <HN3521><SYSTEM><ACT> Formulas are read from the configuration database
    2018-08-11 08:08:41 <HN3521><SYSTEM><ERR> Error compiling the source code of the formulas:
    Line 602, column 103: error CS0029: Cannot implicitly convert type ‘double’ to ‘byte[]’
    2018-08-11 08:08:41 <HN3521><SYSTEM><ERR> Normal program execution is impossible.
    —> How can I solve this problem?
    in reply to: Rapid Scada Update and license key #4114
    catcute
    Hi Mikhail
    Last time, I have the trouble when stop Scada Server-> it keep stop pending untill I restart the computer. I think my computer have the virus (some files was damaged by virus). Then I install window ,Rapid and update the scada config again but it can not solve problem. If Sacda server run 8 hours or less, it can stop and start ok. If server run over 15 hours, the problem happen!!?
    Scada Server stop pending
    I install the RS on the cloud VPS windows.
    when stop pending, Scada server still log:
    2018-08-10 16:05:33 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
    2018-08-10 16:06:20 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data table is completed
    2018-08-10 16:06:36 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
    2018-08-10 16:06:43 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data table is completed
    Full log:
    2018-08-10 16:00:02 <HT-PC><SYSTEM><ACT> Command 0x07 (request command) is received from the client 127.0.0.1
    2018-08-10 16:00:02 <HT-PC><SYSTEM><ACT> Command 0x03 (write current data) is received from the client 127.0.0.1
    2018-08-10 16:00:03 <HT-PC><SYSTEM><ACT> Command 0x07 (request command) is received from the client 127.0.0.1
    2018-08-10 16:00:03 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data table is completed
    2018-08-10 16:00:03 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
    2018-08-10 16:00:03 <HT-PC><SYSTEM><ACT> Command 0x03 (write current data) is received from the client 127.0.0.1
    2018-08-10 16:00:03 <HT-PC><SYSTEM><ACT> Command 0x0C (request files modification time) is received from the client 127.0.0.1
    2018-08-10 16:00:03 <HT-PC><SYSTEM><ACT> Obtaining the modification time of the file C:\SCADA\ArchiveDAT\Cur\current.dat
    2018-08-10 16:00:03 <HT-PC><SYSTEM><ACT> Command 0x08 (open and read file) is received from the client 127.0.0.1
    2018-08-10 16:00:03 <HT-PC><SYSTEM><ACT> Opening file C:\SCADA\ArchiveDAT\Cur\current.dat
    2018-08-10 16:00:04 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data table is completed
    2018-08-10 16:00:04 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
    2018-08-10 16:00:04 <HT-PC><SYSTEM><ACT> Command 0x07 (request command) is received from the client 127.0.0.1
    2018-08-10 16:00:04 <HT-PC><SYSTEM><ACT> Command 0x03 (write current data) is received from the client 127.0.0.1
    2018-08-10 16:00:04 <HT-PC><SYSTEM><ACT> Command 0x0C (request files modification time) is received from the client 127.0.0.1
    2018-08-10 16:00:04 <HT-PC><SYSTEM><ACT> Obtaining the modification time of the file C:\SCADA\ArchiveDAT\Cur\current.dat
    2018-08-10 16:00:04 <HT-PC><SYSTEM><ACT> Command 0x08 (open and read file) is received from the client 127.0.0.1
    2018-08-10 16:00:04 <HT-PC><SYSTEM><ACT> Opening file C:\SCADA\ArchiveDAT\Cur\current.dat
    2018-08-10 16:00:05 <HT-PC><SYSTEM><ACT> Command 0x07 (request command) is received from the client 127.0.0.1
    2018-08-10 16:00:05 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data table is completed
    2018-08-10 16:00:05 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
    2018-08-10 16:00:05 <HT-PC><SYSTEM><ACT> Command 0x0C (request files modification time) is received from the client 127.0.0.1
    2018-08-10 16:00:05 <HT-PC><SYSTEM><ACT> Obtaining the modification time of the file C:\SCADA\ArchiveDAT\Cur\current.dat
    2018-08-10 16:00:05 <HT-PC><SYSTEM><ACT> Command 0x08 (open and read file) is received from the client 127.0.0.1
    2018-08-10 16:00:05 <HT-PC><SYSTEM><ACT> Opening file C:\SCADA\ArchiveDAT\Cur\current.dat
    2018-08-10 16:00:06 <HT-PC><SYSTEM><ACT> Command 0x07 (request command) is received from the client 127.0.0.1
    2018-08-10 16:00:06 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data table is completed
    2018-08-10 16:00:06 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
    2018-08-10 16:00:07 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data table is completed
    2018-08-10 16:00:07 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
    2018-08-10 16:00:08 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data table is completed
    2018-08-10 16:00:08 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
    2018-08-10 16:00:09 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data table is completed
    2018-08-10 16:00:09 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
    2018-08-10 16:00:10 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data table is completed
    2018-08-10 16:00:10 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
    2018-08-10 16:00:11 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data table is completed
    2018-08-10 16:18:45 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
    2018-08-10 16:18:46 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data table is completed
    2018-08-10 16:18:46 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
    2018-08-10 16:18:47 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data table is completed
    2018-08-10 16:18:47 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
    2018-08-10 16:18:48 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data table is completed
    2018-08-10 16:18:48 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
    2018-08-10 16:18:49 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data table is completed
    2018-08-10 16:18:49 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
    2018-08-10 16:18:50 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data table is completed
    2018-08-10 16:18:50 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
    2018-08-10 16:18:51 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data table is completed
    2018-08-10 16:18:51 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
    2018-08-10 16:18:52 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data table is completed
    2018-08-10 16:18:52 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
    2018-08-10 16:18:53 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data table is completed
    2018-08-10 16:18:53 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
    2018-08-10 16:18:54 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data table is completed
    2018-08-10 16:18:54 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
    2018-08-10 16:18:55 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data table is completed
    2018-08-10 16:18:55 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
    2018-08-10 16:18:56 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data table is completed
    2018-08-10 16:18:56 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
    2018-08-10 16:18:57 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data table is completed
    2018-08-10 16:18:57 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
    2018-08-10 16:18:58 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data table is completed
    2018-08-10 16:18:58 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
    2018-08-10 16:18:59 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data table is completed
    2018-08-10 16:18:59 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
    2018-08-10 16:19:00 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data table is completed
    2018-08-10 16:19:00 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
    2018-08-10 16:19:00 <HT-PC><SYSTEM><ACT> Writing snapshot in the minute data table is completed
    2018-08-10 16:19:00 <HT-PC><SYSTEM><ACT> Writing snapshot in the minute data copy table is completed
    2018-08-10 16:19:01 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data table is completed
    2018-08-10 16:19:01 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
    2018-08-10 16:19:02 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data table is completed
    2018-08-10 16:19:02 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
    2018-08-10 16:19:03 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data table is completed
    2018-08-10 16:19:03 <HT-PC><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
    in reply to: Display and Set the String Value for tag #4112
    catcute
    in reply to: Display and Set the String Value for tag #4111
    catcute
    Pls check link:
    in reply to: Modbus Slave mode #3520
    catcute
    Hi Mikhail
    I intend to read data of device from my software and maping data to Modbus communicator. If Rapid Scada suport Modbus Slave, I can write data directly use modbus protocol. But with Rapid Scada as TCP server, I still can’t open tcp connection with Local tcp port 502, error:The network connection was refused by the server.
    in reply to: Modbus Slave mode #3509
    catcute
    Hi Pieter, Line 1 is configed work as Modbus Master: it will send request and read answer from device. Line 8 is configed as Modbus Slave: it will passsive receive request from another device or software and answer the request. That is my understand, I don’t know it is correct in Rapid Scada or not.
    in reply to: No library found for component #3447
    catcute
    Problem come from that I’ve not active Basic scheme components plugin yet! :))
    in reply to: No library found for component #3446
    catcute
    Hi Mikhail
    I checked Web log( hope correct!), but i can not find out problem.
    2018-04-10 09:06:21 <HN3521><DefaultAppPool><ACT> Initialize common web application data
    2018-04-10 09:06:21 <HN3521><DefaultAppPool><ERR> Error loading the plugin assembly C:\SCADA\ScadaWeb\bin\PlgChartPro.dll:
    Could not load file or assembly ‘file:///C:\SCADA\ScadaWeb\bin\PlgChartPro.dll’ or one of its dependencies. The system cannot find the file specified.
    2018-04-10 09:06:21 <HN3521><DefaultAppPool><ERR> Error loading the plugin assembly C:\SCADA\ScadaWeb\bin\PlgDashboard.dll:
    Could not load file or assembly ‘file:///C:\SCADA\ScadaWeb\bin\PlgDashboard.dll’ or one of its dependencies. The system cannot find the file specified.
    2018-04-10 09:06:21 <HN3521><DefaultAppPool><ERR> Error loading the plugin assembly C:\SCADA\ScadaWeb\bin\PlgElasticReport.dll:
    Could not load file or assembly ‘file:///C:\SCADA\ScadaWeb\bin\PlgElasticReport.dll’ or one of its dependencies. The system cannot find the file specified.
    2018-04-10 09:06:22 <HN3521><DefaultAppPool><ACT> Connect to SCADA-Server “localhost”
    2018-04-10 09:06:22 <HN3521><DefaultAppPool><ACT> Refresh the tables of the configuration database
    2018-04-10 09:06:23 <HN3521><DefaultAppPool><ACT> Fill input channels properties
    2018-04-10 09:06:23 <HN3521><DefaultAppPool><ACT> Fill output channels properties
    2018-04-10 09:06:23 <HN3521><DefaultAppPool><ACT> Fill input channel statuses properties
    2018-04-10 09:06:23 <HN3521><DefaultAppPool><ACT> User information has been added. IP address: ::1. Session: sriqvuhtyumvpbivzxbrnndb
    2018-04-10 09:06:37 <HN3521><DefaultAppPool><ACT> Login: admin (Administrator). IP address: ::1
    2018-04-10 09:06:37 <HN3521><DefaultAppPool><ACT> User information has been updated. IP address: ::1. Session: sriqvuhtyumvpbivzxbrnndb
    2018-04-10 09:06:38 <HN3521><DefaultAppPool><ACT> Retrieve components from the installed plugins
    2018-04-10 09:11:04 <HN3521><DefaultAppPool><ACT> Logout: admin. IP address: ::1
    2018-04-10 09:11:04 <HN3521><DefaultAppPool><EXC> Error getting extended current data by the filter where channels= , view id=18:
    Scada.ScadaException: User not logged on.
    at Scada.Web.UserMonitor.CheckLoggedOn(UserRights& userRights, Boolean throwOnFail)
    at Scada.Web.ClientApiSvc.GetCurCnlDataExt(String cnlNums, String viewIDs, Int32 viewID)
    2018-04-10 09:11:05 <HN3521><DefaultAppPool><ACT> Login: admin (Administrator). IP address: ::1
    2018-04-10 09:11:05 <HN3521><DefaultAppPool><ACT> User information has been updated. IP address: ::1. Session: sriqvuhtyumvpbivzxbrnndb
    2018-04-10 09:11:05 <HN3521><DefaultAppPool><ACT> Retrieve components from the installed plugins
    in reply to: Scheme Symbols/IMG #3432
    catcute
    Hi, I’ve just find out the answer!
    in reply to: Scheme Symbols/IMG #3430
    catcute
    Hi,is svg image adready support in scheme? And how can i use it? Thanks!
