Administrator does not run
Forum Home Forums Installation Issues Administrator does not run
  • #3165
    santiago
    I have installed the scada without problems, all apps run except administrator
    • This topic was modified 7 years, 6 months ago by Mikhail.
    #3166
    santiago
    another issue: workstation (web application) icon does’nt exist
    #3169
    Administrator: install MS SQL Compact from the Prerequisites folder.
    Webstation: use the link http://localhost/scada to open the web app.
    Please create different topics for different issues.
    #4770
    CR
    Sorry Sir,
    I have the same issue and I cannot find the “MS SQL Compact from the Prerequisites folder”. I’ll appreciate your help.
    #4773
    These are
    SSCERuntime_x86-ENU.msi
    SSCERuntime_x64-ENU.msi
    You should install both of them.
    #4785
    CR
    Thanks a lot for your support, it worked fine !
    #5078
    mitesh
    Hi Mikhail,
    I want to Display the exact date and time when event occurs. In Administrator i have selected channel type as hourly real. i am getting wrong date (30/12/1899) and time (00.00.00). Please help me to display exact date and time.
    Ex: Event Date Time
    High Temperature : 70°C 27/02/2019 10:35:40
    #5081
    Please create a new topic for the new question.
    Where you need to display date and time?
    #5109
