C# Program Execution Module (PLC Emulator)
Forum Home › Forums › Development and Integration › C# Program Execution Module (PLC Emulator)
  • #18116
    Link to the release ModSoftPlc_V6.4.1.2
    Video on setting up on google disk
    Video on setting up on mail.ru
    Link to GIT with sample programs
    The module has two operating modes.
    Lite is free. It has limitations:
    – there is no initialization of variables at server startup
    – there is no retention of variables (Retain)
    – it is not possible to run calendar programs (this part is still in development)
    Pro mode has no restrictions.
    For programs to work, files are created in the Server/Storage folder – an example SoftPlc_PRG_ID0.xml
    The program has an index, according to the location in the settings file.
    As long as the file exists in the Storage folder, the download always takes place from it.
    To restart the program, you need to perform two identical steps.
    – open the module settings, change the Restart_Program setting to true in the required program, save and transfer to the server
    – After that, open the module settings again and change the variable to false and transfer the data to the server again.
    This is due to the fact that the module itself cannot work with comments in xml files during serialization.
    • This topic was modified 4 months, 2 weeks ago by manjey73.
    #18134
