Toggle and LED
Forum Home › Forums › Understanding the Software › Toggle and LED
  • #10636
    victorlam
    I try to set up a toogle and LED under Scheme Editor. After set up, I try to toogleas ON and OFF. My LED cannot be changed from RED to GREEN or GREEN to RED when using the toogle switch. But I can change the color under register 40002 as 0. Then LED color will be RED. When register 40002 is 1, then LED color is green again. What is my error here? How can I correct this?
    I assume some logic is missing here but no glue.
    #10640
    There it is necessary to apply a kind of formula to change the color of the switch, Now there is no computer at hand from which I can look but I do not remember the memory…
