The ON command is being rejected by Server
Forum Home › Forums › Communicating with Devices › Modbus › The ON command is being rejected by Server
  • #9975
    dp_palai
    Hello, I am developing an application where I am connecting RAPID SCADA to Devices using Modbus TCP. I can read and send commands to the first device in the added devices under Modbus TCP communication line. But when I am trying to send ON/1 command to the second device, message pops up as ‘The Command is rejected by the server’. But I can read and write continuous values for the same device. Please help to fix it. Thanks in advance.
    • This topic was modified 4 years, 10 months ago by Mikhail.
    #10001
    Please provide a screenshot of an output channel that is used to send commands to the 2nd device.
    Also try sending commands via Communicator user interface.
    #10003
    dp_palai
    I am sorry. I should have posted earlier. This problem is solved. Thanks for taking out time to respond.
    #10007
    OK 🙂
