Swapping command values
Forum Home › Forums › Understanding the Software › Swapping command values
  • #16660
    oley
    I have a device with controllable switches.
    I can open the switch by writing the data 0x0000 and close it with 0xFF00.
    I realized this in SCADA by creating commands like Coils(0X) and assigned created channels to a dynamic image.
    The standard way it works is that on click an On(green) and Off(red) window appears.
    Clicking on Off(red) opens the switch, and clicking on On(green) closes it.
    I need the exact opposite action: On(green) opens and Off(red) closes.
    Is the solution a negation in the channel using a formula?
    Best regards
    #16661
    if you are using an enumeration, then add your own.
    ONN: green; OFF:red
    by analogy, or any other at your discretion
    #16669
    In the output formula of the channel, put something like
    Cmd > 0 ? 0xFF : 0x00
    If it doesn’t work, make screenshots.
    #16670
    In case of Modbus coils
    Cmd > 0 ? 0 : 1
    #16688
    oley
    thank you. The custom enumeration works properly.
    Best regards
