Step 11 fails
Forum Home › Forums › Installation Issues › Step 11 fails
  • #9863
    mterebessy
    11. Execute the script to install daemons:
    sudo /opt/scada/svc_install.sh
    From the console:
    user@hmi:/opt/scada$ sudo /opt/scada/svc_install.sh
    chmod: cannot access ‘./scadaagent’: No such file or directory
    update-rc.d: error: unable to read /etc/init.d/scadaagent
    chmod: cannot access ‘./scadaserver’: No such file or directory
    update-rc.d: error: unable to read /etc/init.d/scadaserver
    chmod: cannot access ‘./scadacomm’: No such file or directory
    update-rc.d: error: unable to read /etc/init.d/scadacomm
    The svc_install.sh seems to have commands for changing the attributes of the files, but not actually installing the relevant files. What’s missing here?
    #9865
    Look at the code svc_install.sh Have you exactly copied the required files to the /etc/init.d folder?
    What is your system?
    • This reply was modified 4 years, 10 months ago by manjey73.
    #9867
    mterebessy
    Where in the install does it say to copy those files? Also, there are similarly named files, but different in capitalization, and they are directories vs files.
    #9868
    2. Copy the scripts from the daemons folder to /etc/init.d
    You probably tried to copy the boot scripts under a regular user and did not notice that there is no access, since /etc/init.d is not available to a regular user for writing.
    #9870
    mterebessy
    That was it…not sure why it didn’t copy the first time. I was able to run it via sudo. Thank you.
    #9873
    The daemons (scadaagent, scadacomm and scadaserver) should be copied to /etc/init.d
    Yes, you likely need root access to copy them into init.d
    sudo is a proper way.
