Hi
Now:
I have an embedded pc collecting data from sensors using the Modbus RTU protocol. I have total access to the embedded pc software so I can change all options. At 5 minute intervals, the embedded pc software sends the data, in JSON format, to a remote server (RS) where it is parsed and stored in a database.
Using Rapid SCADA:
I want to replace the software on the remote server (RS) with Rapid SCADA. Can Rapid SCADA understand JSON text or should I send the data, every 5 minutes, from the embedded pc software to the server in another format? What format do you suggest?
sensor ——-> embedded pc ——————> remote server
Matt
