Scheme Editor : Dropdown List of Commands
Forum Home › Forums › Development and Integration › Scheme Editor : Dropdown List of Commands
  • #17058
    rapidscadaaks
    Hi
    I will appreciate assistance for creating a list of commands to open up when a button in pressed Rapid Scada Scheme for selecting command to be sent to Output Channel.
    Thanks in advance
    #17059
    So far, it is possible to select commands through enumerations. Create an enumeration, and specify it in the Command Format. Get a window with buttons and names from the list. Then use the formula to convert the values 0, 1, 2, etc. into the necessary data.
    To display the list, you probably need to make the appropriate element in the schema editor.
    #17065
    Now you can setup a channel to show a command dialog that contains several buttons with command values.
    In the next generation of mimics, it will be possible to do like that https://ibb.co/rR1mWn2H
    #17069
    rapidscadaaks
    Hi Mikhail
    Can you please guide how to setup a channel to show a command dialog that contains several buttons with command values ?
    #17076
    1. Create a channel with enumeration format. See channel 104 as an example (HelloWorld project).
    2. Make sure that a command dialog with buttons is shown in a table view.
    3. Set a sending command action for a scheme component.
    #17083
    rapidscadaaks
    Hi Mikhail
    Thanks for your reply.
    1. While going through the Formats table I observed that in some of the Formats there is a “;” before – kindly enlighten
    2. I could not understand srl. no. 2. Kindly elaborate a bit
    Thank you once again
    #17084
    1. It is an empty value for the first item. Likely you don’t need an empty value.
    2. After configuring a channel, click a rocket button in a table view to check the result.
