RapidScada for Respberry Pi
Forum Home Forums Rapid SCADA on Linux and Raspberry Pi RapidScada for Respberry Pi
This topic contains 5 replies, has 2 voices, and was last updated by Mikhail Mikhail 1 year, 9 months ago.
  • #2089
    lawrence26gta
    Hi, can someone please help me on Respberry Pi. I’m not sure which device does support with RapidScada. I’m looking your help to choose Respberry Pi device with USB, ethernet port, internal memory & touch screen display where i can setup RapidScada. Appreciate your suggestion.
    #2090
    I recommend Raspberry Pi 3 Model B. Usually, I connect to RPi remotely using Putty and WinSCP to configure it, and don’t need a screen for RPi.
    #2091
    lawrence26gta
    Is it possible to replace standard HMI with Respberry Pi with Display and mount it on Panel? I’ve an thinking to mount Respberry Pi device with Display and install RapidScada for standalone Modbus communication with PLC. Please suggest.
    #2093
    In general, yes. You should find out how to run browser in kiosk mode on Raspberry startup.
    #2105
    lawrence26gta
    Hey Mikhail, Can i used Raspberry Pi Emulation for Windows with QEMU? I’m looking to test it prior to buy hardware. Appreciate your help, Thanks!
    #2106
    Hi! To be honest, I have no info about RPi emulation. If you run Rapid SCADA on the emulator, please let me know.
