On – Off Value Changes
Forum Home › Forums › Understanding the Software › On – Off Value Changes
  • #4057
    Gonederra
    I’ve got a problema configuring RapidScada for a TCP-IP protocol. The thing is, that if I want to turn on the device I need the value 0x08h in a certain address, while if I want it off, I need 0x04h.
    Is there any way to change the Off-On command that comes preinstallated in the system so off means 4 and on means 8 (I don’t have any problems on the address colocation), or do I need to create any new commands? If so, how is it possible to do it?
    Thanks.
    #4060
    Yes, just use a formula for an output channel. For example: Cmd <= 0 ? 4 : 8
