I have to read and write a value stored in HR1. I Created in Modbus device template BOTH a group parameter (Signal 1) wih HR1 and a Command parameter on HR1. then in interface i use a dinamic text to display the value of HR1 and a button to send the command if i want to modify HR1. All is working. But my question is this: is there a possibility that if i click on the dinamic text i can directly modify the value? This operativity is very common on SCADA HMI panels.
thanks for any help.
