Forum Home › Forums › Development and Integration › ModAutoControl not working?
- This topic has 5 replies, 2 voices, and was last updated 10 years, 6 months ago by
inpelsa.
May 23, 2016 at 4:20 pm #1226
inpelsaParticipantHi Mikhail!
Modautocontrol is configured to send an email every day at 13h, and it does it… it’s working.
But this weekend several triggers should have been triggered… but it doesn’t.
modautocontrol.xml :
<?xml version="1.0" encoding="utf-8"?> <ModAutoControl> <Triggers> <Trigger name="Alarmas Regulador A" type="CnlDataTrigger"> <CnlDataTriggerProps> <CnlNum>805</CnlNum> <ChkCnlVal>true</ChkCnlVal> <CnlValCond> <CompareOperator1>GreaterThan</CompareOperator1> <CompareArgument1>0</CompareArgument1> <LogicalOperator>None</LogicalOperator> <CompareOperator2>LessThan</CompareOperator2> <CompareArgument2>0</CompareArgument2> </CnlValCond> <ChkCnlStat>true</ChkCnlStat> <CnlStat>0</CnlStat> </CnlDataTriggerProps> <Commands> <Command cmdTypeID="1"> <KPNum>44</KPNum> <CmdNum>1</CmdNum> <CmdData>6561626172636140696E70656C73612E6C6564657276616C2E65733B416C61726D6120526567756C61646F7220413B416C61726D6120616374697661646120656E20526567756C61646F722041</CmdData> <EditMode>Str</EditMode> <CopyCmdVal>false</CopyCmdVal> </Command> </Commands> </Trigger> <Trigger name="Alarmas Regulador B" type="CnlDataTrigger"> <CnlDataTriggerProps> <CnlNum>1008</CnlNum> <ChkCnlVal>true</ChkCnlVal> <CnlValCond> <CompareOperator1>GreaterThan</CompareOperator1> <CompareArgument1>0</CompareArgument1> <LogicalOperator>None</LogicalOperator> <CompareOperator2>LessThan</CompareOperator2> <CompareArgument2>0</CompareArgument2> </CnlValCond> <ChkCnlStat>true</ChkCnlStat> <CnlStat>0</CnlStat> </CnlDataTriggerProps> <Commands> <Command cmdTypeID="1"> <KPNum>44</KPNum> <CmdNum>1</CmdNum> <CmdData>6561626172636140696E70656C73612E6C6564657276616C2E65733B416C61726D6120526567756C61646F7220423B416C61726D6120616374697661646120656E20526567756C61646F722042</CmdData> <EditMode>Str</EditMode> <CopyCmdVal>false</CopyCmdVal> </Command> </Commands> </Trigger> <Trigger name="Alarmas Regulador C" type="CnlDataTrigger"> <CnlDataTriggerProps> <CnlNum>1308</CnlNum> <ChkCnlVal>true</ChkCnlVal> <CnlValCond> <CompareOperator1>GreaterThan</CompareOperator1> <CompareArgument1>0</CompareArgument1> <LogicalOperator>None</LogicalOperator> <CompareOperator2>LessThan</CompareOperator2> <CompareArgument2>0</CompareArgument2> </CnlValCond> <ChkCnlStat>true</ChkCnlStat> <CnlStat>0</CnlStat> </CnlDataTriggerProps> <Commands> <Command cmdTypeID="1"> <KPNum>44</KPNum> <CmdNum>1</CmdNum> <CmdData>6561626172636140696E70656C73612E6C6564657276616C2E65733B416C61726D6120526567756C61646F7220433B416C61726D6120616374697661646120656E20526567756C61646F722043</CmdData> <EditMode>Str</EditMode> <CopyCmdVal>false</CopyCmdVal> </Command> </Commands> </Trigger> <Trigger name="Test de las 13h" type="TimeTrigger"> <TimeTriggerProps> <Mode>EveryDay</Mode> <DaysOfWeek> <Sun>false</Sun> <Mon>false</Mon> <Tue>false</Tue> <Wed>false</Wed> <Thu>false</Thu> <Fri>false</Fri> <Sat>false</Sat> </DaysOfWeek> <Dates /> <Times> <Time>13:00:00</Time> </Times> </TimeTriggerProps> <Commands> <Command cmdTypeID="1"> <KPNum>44</KPNum> <CmdNum>1</CmdNum> <CmdData>6561626172636140696E70656C73612E6C6564657276616C2E65733B54657374204175746F636F6E74726F6C203133683B456C206D6F64756C6F206465206175746F636F6E74726F6C20736967756520656E2066756E63696F6E616D69656E746F2E2E2E</CmdData> <EditMode>Str</EditMode> <CopyCmdVal>false</CopyCmdVal> </Command> </Commands> </Trigger> </Triggers> </ModAutoControl>2016-05-20 16:30:18 Start ModAutoControl module 2016-05-20 18:16:33 Module ModAutoControl is stopped -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- 2016-05-20 18:16:33 Start ModAutoControl module 2016-05-21 13:00:00 Trigger "Test de las 13h" raises 2016-05-21 13:00:00 Send command to Device 44. Command number: 1 2016-05-22 13:00:00 Trigger "Test de las 13h" raises 2016-05-22 13:00:00 Send command to Device 44. Command number: 1 2016-05-22 21:37:33 Trigger "Alarmas Regulador A" raises 2016-05-22 21:37:33 Send command to Device 44. Command number: 1 2016-05-23 13:00:00 Trigger "Test de las 13h" raises 2016-05-23 13:00:00 Send command to Device 44. Command number: 1 2016-05-23 16:21:33 Module ModAutoControl is stopped -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- 2016-05-23 16:21:34 Start ModAutoControl module 2016-05-23 16:37:31 Module ModAutoControl is stopped3 channel data plotted, several changes on all channels, NONE email received:
PD: forum tips:
– Find a way to add pictures right here, not depending on external servers (slow, annoying)
– Enable ‘notify me of follow-up….’ by default
– Make thread messages widerMay 23, 2016 at 4:26 pm #1227
inpelsaParticipantSorry, I received one email as stated on the log:
“Alarma activada en Regulador A” on Sunday 22th at 21:37:33
Why no more alerts !!??
May 23, 2016 at 4:33 pm #1228
inpelsaParticipantSeems at email’s time there was a communication fault:
But 1 hour before it same event happened… and there was no email !!??
May 24, 2016 at 6:16 am #1236
Your triggers are configured as
<CnlStat>0</CnlStat>It means that channel status must be 0 (undefined) to fire the trigger.
May 24, 2016 at 6:22 am #1237
MikhailModeratorPD: forum tips:
I recommend Extended support service. It includes Redmine ticket tracker which is much more comfortable.
May 24, 2016 at 11:10 am #1239
inpelsaParticipantMmm… true… is true.
I thought it was the output status.
thanks!
