Loss Modbus Slave Driver’s computer code
Forum Home Forums Installation Issues Loss Modbus Slave Driver’s computer code
  • #16510
    Alex.Chien
    Hi Support:
    I can’t get computer code from “Modbus Slave Driver”,it show “No data”,
    I already try restart rapid scada’s all service,but i still can’t see the code,
    Can you help me ??
    Thanks.
    Our scada version is 6.2.0.0
    Modbus Slave Driver version is 6.0.0.1
    #16512
    Apparently, it is necessary for the driver to start, that is, to make the minimum settings for its operation. If the driver is not running, for example, there is no configuration, then the PC code will not be created. See what the driver writes in the logs.
    This applies to all drivers, plug-ins, and modules.
    #16513
    In short, configure a communication line and device, and you will see the code in the log.
