Loosing Data Point
Forum Home Forums Runtime Bugs Server Bugs Loosing Data Point
  • #2329
    Inoak
    I have a Installation of Scada Server on a Ubuntu Linux. I’am Reading Datapoints over Modbus TCP/IP connection. This works properly. After a few day i’am loosing some Datapoints. When i restart the Scada Server then works the system properly for a few new days.
    Thanks for Help
    #2331
    Please provide the necessary screenshots.
    #2333
    Inoak
    Data Point Loosing
    #2334
    Inoak
    • This reply was modified 8 years, 10 months ago by Inoak.
    #2337
    Data are not lost. The values equal 0 from 12am to 12pm.
    The next time when the issue repeats, you need to check communication line log in Communicator and find out the cause of the error.
    #2338
    Also check that Communicator is connected to SCADA-Server.
    #2341
    Inoak
    Picture 1
    Picture 2
    Picture 3
    For me looks that i have a problem with the Master
    #2342
    Sometime the received data are incorrect. You can check it by http://modbus.rapidscada.net/ or any other Modbus parser. I recommend to try increasing a delay after request in Communicator (Request Sequence tab). Probably the polling speed is too fast for the particular device and network.
