IEC 101 to IEC104 data conversion via IP
Forum Home › Forums › Communicating with Devices › IEC 101 to IEC104 data conversion via IP
  • #920
    arcan8888
    Hi there,
    I’ve been recently contracted to develop and implement a solution which uses and IP based medium to transport IEC101 data from an RTU to a IEC104 SCADAMASTER.
    The SCADA system in question is to relay information for an electric utility company to track its substations.
    I have noticed that when my RTU is online, the SCADAMASTER will only see it as “ONLINE” for a few minutes and then registers the RTU as “OFFLINE” until traffic or data is sent from the RTU to the SCADAMASTER.
    Has anyone experienced this before?
    #921
    SCADAMaster is the other software. We develop and support Rapid SCADA. If you decide to use Rapid SCADA, I can help you 🙂
