HTTP Activation feature is installed for .NET Framework 4+
Forum Home › Forums › Installation Issues › HTTP Activation feature is installed for .NET Framework 4+
  • #8976
    awei.electrical
    I have across an issue in the installations, which was raised by many others in the previous posts.
    Check the configuration of Internet Information Services (IIS)
    Go to
    Control Panel > Programs > Turn Windows features on or off
    and make sure that WCF Services > HTTP Activation feature is installed for .NET Framework 4+,
    whereas the components for .NET Framework 3.5 are switched off
    All the boxed ticked are identical as per the instruction file
    https://rapidscada.net/doc/content/latest/en/installation-and-run/software-installation.html
    The only exception is mine is .NET 4.8 instead of .NET 4.6
    Can you please assist, thanks.
    #8977
    This warning is always displayed. If you ticked the required checkboxes, ignore the warning and continue.
    There is a remote help service if needed.
    #8978
    awei.electrical
    Hi, with the warning displayed, I do not think the installations has completed and I can not start the software
    #8982
    Could you copy the full installation log here?
    #8995
    awei.electrical
    Hi, I have found the exe application file in a sub-folder to start the software. All good now, thanks.
    #8996
    OK 🙂
