How to modify alarms in Schemes?
Forum Home › Forums › Understanding the Software › How to modify alarms in Schemes?
  • #2128
    jmacias552
    How can we modify the point alarms from the interface web scheme?
    This is importatn due that from web there is no access to admin application.
    Thanks a lot
    #2129
    You can create additional input channels for storing the points, and the input channels indicate alarms. Then use formulas to calculate alarm states. You also need output channels to change the points from the web UI.
    We can configure an example together if you purchase a training. Otherwise try it by yourself and ask questions here providing screenshots of the settings.
    #2130
    jmacias552
    Thank you Mikhail, I will try to configure and get back to you.
    Regards,
