How to log data when event happens
Forum Home › Forums › Understanding the Software › How to log data when event happens
  • #6664
    avesh
    I would like to log the data (from 3 different tags) i.e Operator, Machine, Logtime when a Boolean event (State tag) goes from low to high and vice versa. What modules do I require and do you have any example that I can go through?
    Tag data capture based on event change
    • This topic was modified 6 years, 6 months ago by avesh.
    #6667
    You should develop custom SQL scripts to check a flag in the external SQL database.
    To set the flag in the external database from Rapid SCADA the DB export module should be upgraded.
