Formulas in input channel
Forum Home Forums Understanding the Software Formulas in input channel
  • #2551
    manraj
    Hi there.I am having trouble running codes in the input channel of the Modbus.Basically I have a pipe modal whereby, an input channel is assumed and the assumed value would be calculated in the formula given below to get the output values which is the output channel as well.Please help me out with a simple coding that can be used.Let me know if any changes in to be made.
    p2= output pressure (Output channel)
    p1= input pressure(Input channel)
    ρ=density of water(1000kg/m3)
    f=friction factor ( 0.05)
    L=length of pipe (12m)
    v= velocity of water (3m/s)
    D=pipe diameter (0.1m)
    p2=p1-(ρ*f*L*v2/2D)
    #2555
    1. Add the constants to the Formulas table like this:
    const double D = 0.1;
    2. Create an additional input channel (number 2, for example) of the “Calculated real” type and specify a formula for this channel:
    Val(1)-p*f*L… (I don’t understand the end of the formula)
    1 – is the number of the input channel for p1.
    3. Download the new version of Automatic Control Module
    http://rapidscada.org/download/mod_auto_control/mod_auto_control_5.2.1.0_en.zip
    and setup sending command on change of channel 2
    In case of follow up questions provide screenshots of your settings.
    #2558
    manraj
    1. Do you mean i should add the constants to the Formulas table like this:
    const double p2= output pressure (Output channel)
    const double p1= input pressure(Input channel)
    const double ρ=1000;
    const double f= 0.05;
    const double L= 12;
    const double v= 3;
    const double D= 0.1;
    Do i need to add on anything else at the start of the codes like “namespace” or “system” since its reads programming C#.Do you have any working example format of formulas so I can study how to insert formulas in the channel.
    2.So I should have 2 input channels is it?.Input channel 1 should be the value is received from Modbus and channel 2 I should place in formulas in the SCADA administrator.?
    Val(1)-(p*f*L*v^2)/2D–p multiply with f,l, and the square of v.Then divide 2*D
    Thank you!
    • This reply was modified 8 years, 1 month ago by manraj.
    #2564
    const double L= 12;
    const double v= 3;
    #2565
    You don’t need namespace and usings. The examples are already in the Formulas table.
    #2566
    Yes. The input channel 2 is the calculated value that is needed to be sent as a command.
    #2567
    manraj
    I got it thank you very much.I will create the formulas and update here if there is any problem. Thank you!
    #2579
    manraj
    Hi!
    Is there away to place formulas in the condition of a dynamic picture? because i tried putting Val(input channel) but it only read real number.
    #2581
    You should create an input channel of calculated type and use its value for a dynamic picture.
    #2583
    manraj
    So does this mean I only can put a calculated values in the conditions of the dynamic pictures and not the formula itself.
    #2589
    Yes, you right.
