bound property in mimic editor
Forum Home Forums Understanding the Software bound property in mimic editor
  • #17156
    oday
    Dears,
    in scheme editor we used to bound property of a button to an input channel, which can enable/disable or control button visibility, now in mimic editor, in the button configuration, it is not there, instead i see property bindings, which i can add items, in the item there is
    property name: which i assume it is (Enabled)
    data source : i put the input channel number (113) –> it is input channel value from modbus coil
    data member : value
    Format : blank
    what i am missing here?
    #17157
    The visible and accessible properties are called: visible, enabled
    #17158
    oday
    many thanks for the fast reply dear 🙂
    I didn’t know that this Capital letter in the property name would break it XD.
    #17162
    We are planning to develop a dialog to pick a property. It will solve the issue.
    #17165
    oday
    Hello Mikhail,
    I know that Mimic view is still new and experimental,
    you are doing a very good job so far.
    Good Luck 🙂
    #17171
    Thank you 🙂
