Formula does not stop
Forum Home › Forums › Understanding the Software › Formulas › Formula does not stop
  • #7739
    rokas25
    Hello, I have a problem with formula. Formula is simple, it should add the value once, but it looks like it is not stopping, keeps adding the value from other channel.
    Cnl value is working ok, but the adding is infinite. I only need to sum up two current channel values.
    https://ibb.co/L9dFtP6
    #7740
    rokas25
    For example:
    Cnl value is 10 and Val(11257) is 0, then I get right value, but if Val(11257) is not 0, for example its 10, it adds up every second or even more frequent, so what I see is 10,12,13,14,15 and etc, it adds up fast.
    I need to make it a constant value, not adding numbers up really fast
    #7742
    Please right click the input channel, open properties and make a screenshot of all channel properties.
    #7747
    rokas25
    https://imgur.com/QEGIfEk
    There is status and substatus lines, but I need to make it into one, so I am trying to make it to show as 0,00 or 0.00, but when substatus gets some value instead of 0, it keeps adding up numbers constantly.
    • This reply was modified 5 years, 11 months ago by rokas25.
    #7753
    You have to set Signal to an empty string. Otherwise the channel gets data from a device.
