Extra Scheme Components trial — Trend axis labels/gridlines not
Forum Home › Forums › Understanding the Software › Extra Scheme Components trial — Trend axis labels/gridlines not
  • #18314
    Daniel1113
    I’m testing the trial version of the Extra Scheme Components plugin — the Mimic-compatible package (“Download the plugin for Rapid SCADA 6.x (new mimics)”), not the classic Scheme version. I added the Trend component (found under the “EXTRA” category in Mimic Editor’s component palette) to a Mimic diagram to display a custom historical archive (1-second writing period, Code=”Sec”, Bit=16).
    The line itself is drawn correctly and follows the channel’s value, but no axis labels, tick marks, or gridlines are displayed at all — just a blank white box with the trend line.
    What I’ve tried:
    Set Minimum/Maximum properties correctly (e.g. Minimum=-30, Maximum=300)
    Increased “Period, min” to 10
    Redeployed via Upload Configuration and hard-refreshed the browser (Ctrl+F5)
    Checked browser console — no JavaScript errors
    Confirmed the component renders as a <canvas class=”extra-trend-canvas”> element inside the Mimic diagram
    Environment: Rapid SCADA Webstation 6.2.3.1, Extra Scheme Components 6.1.1.0 (Mimic version, trial license), Mimic Diagram (.mim).
    Is this a limitation of the trial version (axis rendering disabled until purchase), or is there an additional property I’m missing to enable axis/grid display? Any guidance would be appreciated.
    #18315
    I suppose, it requires the configuration files for the chart plugin.
    A chart is displayed in a separate frame by the Chart or Chart Pro plugin.
    Please press 12 to open the browser tools, and check the frame URL, so I can provide more details.
    • This reply was modified 2 months, 1 week ago by Mikhail.
    #18317
    Trend is a simple component.
    To display a full featured chart, use the Frame component with Source Type = Chart.
    See ExtraCompTest.mim as an example.
