Dynamic Pages
Forum Home Forums Understanding the Software Dynamic Pages
  • #14390
    Matt3
    Hi Mi
    I would like some guidance on the structure of the filing system for version 6.2.
    I’m happy adding static pages such as html to the wwwroot/custom folder. I can setup a link in “View” to access the page using the browser.
    However, if I’m using a cshtml page (eg spreadsheet.cshtml) that contains a spreadsheet control (eg spreadsheet.dll), in which folder should I add my page and where should I put the dll?
    Then using ScadaAdmin, I will load the HelloWorld project and go to View.
    I will add a new row as follows…
    Custom\spreadsheet, Web Page, Enterprise, custom/spreadsheet.cshtml, HelloWorld/Spreadsheet
    Kind regards
    Matt
    #14401
    If you use ASP.NET Razor Pages to create your page, you should copy a dll file into the root folder of the web application. Open SCADA\ScadaWeb and check the file structure. Also you can download any additional plugin and check its files.
