Forum Home › Forums › New Ideas › DBExport by Archive Date problem
- This topic has 3 replies, 3 voices, and was last updated 4 years, 9 months ago by
December 9, 2021 at 3:47 am #9748
zjc674810017
ParticipantHi Mikhail
I want to export date to my DB on particular time interval, and I want to choose which archive date I want to export, Current date, Minute date or Hourly date if possible.I dont know how to achieve this. In the official roadmap page, there is example code but it didnt work.
December 9, 2021 at 12:33 pm #9751
The existing Export to DB module exports data when it comes from Communicator to Server application. If you can’t run export manually, share screenshots of your settings, and how you send an export command.
The fixed period mode will be supported in Rapid SCADA 6. It will support PostgreSQL archives out of the box.
January 21, 2022 at 7:03 am #9964zzz
ParticipantNot sure about PostgresSQL, but I tried TimescaleDB which is postgres based. The lesson I have learnt is that I should have use influxdb2 in the first place.
The timescaledb database exploded in size very quickly in 2 weeks (first sync all archive (600chs/30s, 1+year), then 600chs/5s live insertion left on for days), tried all compression tricks mentioned in doc (I re-created and re-imprted the data archive several times taking hours and hours just to make sure, I didn’t mis-operate), nothing helped much. The size droped
by2/3 when switched to influxdb2, and the increament in size also slowed down. After all data in RapidScada archive has been imporpted via socketapi into Influxdb2 the size is bigger than RS’s native format, but not so much – not at all, considering the tradeoff for the abiltiy to use the advanced timeseries analytic queries and customized downsampling.I use postgresql very often, I have nothing against it, This is just a friednly aheadsup for my wasted 1 week in dealing with this mess. Maybe a benchmark or some reasearch on scalablity on the setup will turn out to be benificial.
Timescaledb’s insertion speed is notably faster c.f. influxdb2 in my test. The query performance was initally on par after the db has the right partitioning, but performance decreases notably for some query when the size quicly become unmanagable…
January 21, 2022 at 11:57 am #9972
MikhailModeratorUseful experience. Thank you for sharing it.
