Currency Format
Forum Home › Forums › Understanding the Software › Currency Format
  • #17919
    WayneS
    If I use a C0 format I get a pounds symbol. I’m in New Zealand and we use dollars, albeit our english is closer to UK than US. Windows is cirrectly setup for NZ English and its currency symbol is $ – is there anyway to edit rapid scada to make it $?
    regards
    Wayne
    • This topic was modified 6 months, 3 weeks ago by WayneS.
    #17921
    en-NZ is a culture code for New Zealand. A culture includes the corresponding language and formatting options.
    In the Administrator app, in the Webstation options, select en-NZ culture for the web application.
    The web app will not find the appropriate language files, and should use the existing English language files and the regional culture settings.
    Does it work?
    Format strings can be found here and here.
    #17922
    WayneS
    Hi Mikhail,
    Thank you that worked perfectly.
    Rapid SCADA is working really well.
    regards
    Wayne
