Continue sending command to Modbus device using Auto Control Module
Forum Home Forums Understanding the Software Continue sending command to Modbus device using Auto Control Module
  • #10893
    CCKOH
    Hi Mikhail,
    Im using Auto Control Module to send command to Modbus device by mean of a input channel (Toggle Switch).
    Im notice that the Auto Control module will only send command to Modbus Device when im toggle the switch once (0 to 1).
    Im need the Auto Control Module to continie sending the command to Modbus device if the Toggle Switch in On state (1). Can u help advice any idea to do it.
    Im have a idea, to create another channel (use to trigger Auto Control Module) and apply formula so that the channel will toggle between 0 to 1 continuosly when my toggle switch is On. But im dont hv any idea how to write that formula script. Can u gv me some idea.
    Thks in advance for ur guidances.
    #10894
    There is a repeat commands checkbox of a data trigger. If you provide a screenshot of your trigger, I can give more exact info.
    • This reply was modified 3 years, 8 months ago by Mikhail.
