Communication Log update Error in Administrator
Forum Home › Forums › Understanding the Software › Communication Log update Error in Administrator
  • #18165
    ramiouba
    I just build a project in the version 6.4.6 that uses Modbus driver over serial communication line.
    everything was working good and the “Line Log” in Line State was showing all the data packets transferred between the Scada and the device until the moment that I changed the <LogDir> in “ScadaInstanceConfig.xml” file to the “RAMDISK” drive.
    The data between the Scada and the device is still transferred successfully and the log files in the RAMDISK are updated correctly over the time, but the Line Log and Line State in the Administrator application didn’t change and they still showing the last information before changing the <LogDir> to RAMDisk, although I’ve uploaded the new configuration and restarted all the Scada services but nothing changed. Help please.
    • This topic was modified 4 months ago by ramiouba.
    #18167
    You should restart the ScadaAgent service. Currently, it takes logs from the old locations.
    #18170
    ramiouba
    It works.
