communication lines and devices don't Update in time
Forum Home Forums Runtime Bugs Communicator Bugs communication lines and devices don't Update in time
This topic contains 1 reply, has 2 voices, and was last updated by Mikhail Mikhail 2 years, 6 months ago.
  • #2423
    Avatar
    zhaochengshen
    I found a issue druning my use of the Rapid SCADA.
    When I Editing the configuration database is Completed using the Administraotr application, I passed the button “Pass to Scada-server” and restart the Server service.Then I Right-click on the ” Communication Lines ” and choose the ” Import communication lines and devices” but Communication line and devices don’t renew in communicator. I must close the Communicator application,then reopen the Communicaor application that the Communicaiton lines and devices will to be update from the database. I’ve tested it many times and hopefully it will be fixed
    #2424
    Thank you for your note. This is a known bug. It is not major, so it will be fixed in the next iteration of Communicator improvements.
