Command Values and Write Event
Forum Home › Forums › Understanding the Software › Command Values and Write Event
  • #10634
    victorlam
    For input and output channel, there is settings under command values field. We have Alarm Command 1, Disarm-Am, Execute, Off, Off-ON, ON. Also, there is another write event field that can be optional ticked for the function. May I know what is the meaning for the individual commands here and the meaning for the “write event” here?
    #10641
    These are enumerations, you can create your own.For example, Off;On; Auto and then use in the transmission of commands with buttons. There will be keys with corresponding labels in the command window. As well as the display in the channel if you select the channel format Enumeration
    • This reply was modified 4 years, 2 months ago by manjey73.
