I encountered the following problems when using the autocontrol module,When multiple conditions are met at the same time, the command is triggered. How do I configure the module。
This topic was modified 5 years, 8 months ago by Mikhail.
If you need a trigger that fires on a complex condition, you should add an input channel and calculate the condition using the channel formula. Then specify this channel to the trigger.
