Administrator Chiannels
Forum Home › Forums › Understanding the Software › Administrator Chiannels
  • #10571
    victorlam
    I was confused between input channels number and output channels number. If I set input channel number 101, then the output channel is also 101 or others 102. What is the meaning for 101 and 102 for output channels.
    For output channels, there are channel number on the left hand side. Then there is command number(s) here. What is the meaning for command number here?
    Please help to clarify the relationship between input channel number, output channel number and command number.
    #10572
    The command number is the number that is obtained as a result of configuring the Modbus template command, for example, you specified a register entry command and a number 1 or 2 was created for it, this is the number you specify in the control channel (output channel) The output channel number can be arbitrary and you refer to it in the input channel thus creating a link. Switch to version 6, it now has one channel, just specify its type Input, Input/Output, Output
