Sending email by using Gmail sudden fail
Forum Home › Forums › Understanding the Software › Sending email by using Gmail sudden fail
Viewing 10 posts - 31 through 40 (of 40 total)
  • #12126
    hethongscada62
    Dear Mr. Mikhail,
    It is now working.
    Thank You for your support
    Han Hoang
    #12127
    victorlam
    Hello Han Hoang,
    Nice to talk with you I also would like to use gmail or other email account to get the notification. Can you share your steps or procedures or do you need to purchase any plug in so that it is successful now?
    THanks for your help and support.
    #12594
    RapidScadaHan
    Dear Vitorlam,
    I have not been purchased any plugin. You have to do wall steps in instruction so that you can get results.
    The best regards
    Han Hoang
    #12595
    RapidScadaHan
    Dear Mr.Mikhail,
    I have been structed a problem in Automatic module. I don’t understand where is wrong, the Automatic module sends an email with wrong alert. For example, the automatic module will be send alert an with value > 100 mA when the Over Leakage Current is up > 100 mA but in my case it is unnormal. You can see it via screenshots bellowing:
    https://ibb.co/cNxcNH1
    The Triger parameters is bellowing
    https://ibb.co/XC7QqB2
    Where is wrong? How to fix it?
    Thanks and best regards
    Han Hoang
    #12606
    It sends the current channel value. Likely, the value became smaller when the module repeats sending email according to the trigger options.
    #12631
    hethongscada62
    Dear Mr.Mikhail,
    Thank you for your reply.
    Can we resolve this problem by configuring a automatic module? That means Automatic sends only a high value.
    Thanks a lot
    Han Hoang
    #12641
    I checked the source code: {CnlVal} variable should show a value that caused the trigger to fire. Could you create a simple project based on HelloWorld to reproduce the issue using data generated by simulator?
    Note: the issue should be also occurred in Rapid SCADA 6, because any new changes are made in the 6th version.
    • This reply was modified 3 years, 5 months ago by Mikhail.
    #12643
    In your screenshot, “On normalization” checkbox is set. Likely, be the message was sent when value became normal.
    #12656
    hethongscada62
    Dear Mr.Mikhail,
    The best regards
    Han Hoang
