Forum Home › Forums › Understanding the Software › Using Formulas › Send command
- This topic has 56 replies, 10 voices, and was last updated 1 year, 7 months ago by
March 11, 2021 at 2:24 pm #8490
MikhailModeratorOK
May 20, 2021 at 3:13 am #8971hethongscada62
ParticipantDear Mr.Mikhail,
Related to this topic” Send command” , can i ask You a question:
Will 2 relays be controlled via only 1 Button?.
That’s mean can the command send 1 value to more than 2 input when the Button clicks?
Thanks and best regards
Han HoangMay 20, 2021 at 12:55 pm #8973
You need Automatic Control Module to send 2 commands by 1 click.
You send the 1st command as usual. A command trigger reacts on the 1st command and sends the 2nd command.May 20, 2021 at 12:56 pm #8974
MikhailModeratorDo you mean that 2 relays are 2 different devices?
May 21, 2021 at 6:02 am #8979hethongscada62
– The Automatic Control module is using on my project now.
– Yes, the 2 relays are 2 different devices. That’s mean only 1 Button can turn On or Off 2 devices at one.
So how to configure the Automatic Control module?
ThanksMay 21, 2021 at 1:10 pm #8984
You should add a new trigger of the command type that reacts on the 1st command. Then add a 2nd command below the created trigger.
December 28, 2021 at 5:20 pm #9834gabeirinhas
ParticipantGood afternoon, is there any way to send a command from the telegram chat, to activate a signal?
I am able to send notifications with a trigger but I wanted to know if it is possible to send commands in the opposite direction.
December 29, 2021 at 1:59 pm #9835
Currently, the Telegram driver doesn’t support receiving commands. It is a good idea for the future improvements.December 29, 2021 at 3:41 pm #9836gabeirinhas
Participantthanks
December 4, 2022 at 2:57 am #11717SGG
ParticipantHello,
If the time duration to poll a device is 5seconds, and I send a command, rapid scada waits till the device is polled before executing that command.Is it possible for rapid scada to suspend/cancel the polling, execute the command then continue/restart the device polling?
Regards.
December 4, 2022 at 8:30 am #11718
manjey73ParticipantThe command is sent immediately, there is a checkbox in the survey settings for polling immediately after the command
December 5, 2022 at 8:53 am #11721
Request timeout cannot be interrupted. Use smaller timeout if needed.
December 5, 2022 at 10:09 am #11724SGG
ParticipantThanks Mikhail, I will use shorter timeouts…thanks also to Manjey.
July 23, 2024 at 4:48 am #15001redass
ParticipantHello, I would like it to send the value immediately (without entering the command) when the button is clicked. This value is e.g. 111e. Does it need to be entered in the formula or is there a function somewhere?
July 23, 2024 at 5:30 am #15002 -
