Forum Home › Forums › Uncategorized Issues › New Web App Idea?
- This topic has 47 replies, 5 voices, and was last updated 9 years, 8 months ago by
August 4, 2016 at 8:16 am #1507
MikhailModeratorHi!
Chart Pro and Chart List components will be implemented for the new web app within a few months. Probably, they will require new keys, but in case that you already have a license, the new keys will be free for you.August 4, 2016 at 11:53 am #1508
inpelsaParticipantFew months… Mmm… Then I would be happy if that memory-eater bug gets fixed in current release 🙂
August 4, 2016 at 5:13 pm #1509
All the forces are aimed for the development of the new web app. You could use both versions simultaneously while it is not fully ready.
September 9, 2016 at 3:49 pm #1599
Washu HakubiParticipantHi does it support custom web pages atm? I tryed to use a custom page but it did not work for me.
September 9, 2016 at 4:58 pm #1600
It has a bit different approach – you should create a plugin like these.In the plugin you are able to implement a new type of view or add an item to the main menu which open your single page.
September 9, 2016 at 5:20 pm #1601
Washu HakubiParticipantok i will give it a try, ty.
September 9, 2016 at 6:02 pm #1602
Washu HakubiParticipanthmmm sorry is there a sample how to use that, i looked arround but i dont know what im suppose to do there.
How would i add the the webpagesample in https://github.com/RapidScada/scada/tree/develop/ScadaWeb/WebPageSample to that plugin? What files i need to pick after i build and where i put em?September 10, 2016 at 8:45 am #1603
MikhailModeratorCould you create a new topic and provide more details about your task? What is displayed by your cutom page?
September 14, 2016 at 2:01 pm #1608
Washu HakubiParticipantGood Morning,
While testing i found some diferences and some issues with the chart in the new webbeta 5.0
First the diference, in the old webview, in the chart we had a show/hidden values so we could see the value of the chart under the chart itself, as show in the picture:
Old Webview ChartOn the new version the show/hidden is not available anymore, is it just a bug or it was removed?
New Webview beta 5.0 ChartOn the webview beta 5.0 chart, while testing in my android phone, i cant zoom in or out, and since my phone has a 3 inch screen, i can only see the red line, the numbers or anything else are too smal to be seen.
September 14, 2016 at 2:45 pm #1609
It is moved to Chart Pro plugin that is under development for now. The minute data is also accessible via the report in Excel format. The report is being developed too ))
Zooming is implemented in Chart Pro using multitouch.
Coming soon 🙂
October 21, 2016 at 7:35 pm #1674
Washu HakubiParticipantGood Afternoon, is there any prediction for when the report feature will be added to scada 5.0? Or for the official release date of 5.0?
October 22, 2016 at 8:51 am #1677
It is done )) Download the beta again.
Most likely, the official release will be in November 2016.October 22, 2016 at 8:55 am #1678
MikhailModeratorAlso Chart Pro for the new web app is ready.
And the new plugin Elastic Report, which allows to generate almost any form of report.
If need them, please let me know (they are not published yet).October 28, 2016 at 2:57 pm #1682
Washu HakubiParticipantI found 2 issues with the new Web beta.
Issue number 1- Users, Roles, Rights are not working right.
I tryed adding a new Role called “TestRole” as number 5, i whent to Users and created the user “Test” as number 20, i whent to right pages and i added the all my pages to it, put the TestRole on it and i clicked on the view checkbox.
Passed to server restarted both server and comunication and i whent to page and tryed logging. It opens the page in blank and say “The requested view does not exist or you have insufficient rights to access it.” This only happens to new roles if i create a user with role guest it “works” (even if i go i check that Guest dont have the right to view 1 of the pages, nothing happens, so works but ignores the rights table).Issue number 2 – Not really an issue but still really anoying, on old web we would put the views we want to show on that settings inside Scadaweb/Config, so i could have lots of diferent pages in the same server, lets say i have 4 clients, i could make a diferent web aplications and only show what i wanted. Now it takes it from the interface so they all have everythings, and i cant show thigns from client A to client B, in fact they cant even know about each other.
So for this new Web i have to have multiple instances of Rapidscada installed on the server to do what i could do easy in the old version.October 29, 2016 at 7:39 am #1683
MikhailModeratorIssue 1. You have to grant access to “folders” which are separate records in Interface table.
If it doesn’t help, post screenshots of the tables, please. -
