ScadaSchemeEditor – Button use
Forum Home Forums Understanding the Software ScadaSchemeEditor – Button use
Viewing 4 posts - 16 through 19 (of 19 total)
  • #4090
    leon
    Hi Mikhail
    Sorry, I am not clear enough.
    Can I use different formulas for different buttons in the window where the command is sent?
    They are all output channels (19).
    https://imgur.com/a/K6Gfpt1
    https://imgur.com/NGl3BMG
    • This reply was modified 8 years, 1 month ago by leon.
    #4095
    A command is bound to an output channel. The output channel has only 1 formula. So you should do all the required calculations in a one formula. Depending the pressed button, you get CmdVal = 0,1,2,… that you can use in the formula.
    #4096
    You can create complex functions to use in formulas, so there is enough tools to do what you need.
    #4097
    leon
    Hi Mikhail
    I understand, thank you.
