Forum Home › Forums › Understanding the Software › Log in web page
- This topic has 22 replies, 4 voices, and was last updated 5 years, 11 months ago by
July 18, 2019 at 2:26 pm #5734
MikhailModeratorYou should update Webstation at least to 5.0.8.0
March 12, 2020 at 6:48 am #6598JW
Participantit seems the auto login url use first user account in user table to login for the first time. later, it use admin account login.
is there any other way to config the auto login to use a specific account?
March 12, 2020 at 6:59 am #6599JW
ParticipantI downloaded the plugin from reply #5729. But I can’t find it from plugin store. where can i check for latest version?
March 12, 2020 at 8:38 am #6600
MikhailModeratorit seems the auto login url use first user account in user table
Yes, you right. We can upgrade the plugin to select specified user for a fee.
This is because the plugin has not been properly documented. The link in the forum is up to date.
November 18, 2020 at 8:54 am #7570JW
ParticipantHi, I tried the auto login module with rapid scada 5.8.1 on both windows and linux. Neither of them work.
When try to use auto login URL, the web show only the following error message.
Application Error
Details:
c:\SCADA\ScadaWeb\Login.aspx(19): error CS0103: The name ‘phrases’ does not exist in the current context——————————————————————————–
Web Log
2020-11-18 10:40:27 <os-server><www-data><ACT> Initialize common web application data
2020-11-18 10:40:27 <os-server><www-data><ACT> Connect to SCADA-Server “localhost”
2020-11-18 10:40:27 <os-server><www-data><ACT> Refresh the tables of the configuration database
2020-11-18 10:40:27 <os-server><www-data><ACT> Fill input channels properties
2020-11-18 10:40:27 <os-server><www-data><ACT> Fill output channels properties
2020-11-18 10:40:27 <os-server><www-data><ACT> Fill input channel statuses properties
2020-11-18 10:40:32 <os-server><www-data><ACT> User information has been added. IP address: ::1. Session: A3B4E3B4CDA8C7978F544E55
2020-11-18 11:20:18 <os-server><www-data><ACT> Request SCADA-Server state
2020-11-18 11:20:18 <os-server><www-data><ERR> Incorrect SCADA-Server response to state request
2020-11-18 11:20:18 <os-server><www-data><ACT> Disconnect from SCADA-Server
2020-11-18 11:20:18 <os-server><www-data><ACT> Connect to SCADA-Server “localhost”
2020-11-18 11:20:18 <os-server><www-data><ACT> User information has been added. IP address: ::1. Session: 9B83F0E5C6DE2ACFC877FA8A
2020-11-18 11:20:20 <os-server><www-data><ERR> Unsuccessful login attempt: admin – Incorrect username or password. IP address: ::1
2020-11-18 11:20:23 <os-server><www-data><ERR> Unsuccessful login attempt: admin – Incorrect username or password. IP address: ::1
2020-11-18 11:20:27 <os-server><www-data><ERR> Unsuccessful login attempt: admin – Incorrect username or password. IP address: ::1
2020-11-18 11:20:37 <os-server><www-data><ERR> Unsuccessful login attempt: admin – Incorrect username or password. IP address: ::1
2020-11-18 11:20:43 <os-server><www-data><ACT> Login: guest (Guest). IP address: ::1
2020-11-18 11:20:43 <os-server><www-data><ACT> User information has been updated. IP address: ::1. Session: 9B83F0E5C6DE2ACFC877FA8A
2020-11-18 11:20:43 <os-server><www-data><ACT> Retrieve components from the installed plugins
2020-11-18 11:20:55 <os-server><www-data><ACT> Logout: guest. IP address: ::1
2020-11-18 11:21:01 <os-server><www-data><ERR> Unsuccessful login attempt: admin – Incorrect username or password. IP address: ::1
2020-11-18 11:21:07 <os-server><www-data><ACT> Login: guest (Guest). IP address: ::1
2020-11-18 11:21:07 <os-server><www-data><ACT> User information has been updated. IP address: ::1. Session: 9B83F0E5C6DE2ACFC877FA8A
2020-11-18 11:21:07 <os-server><www-data><ACT> Retrieve components from the installed plugins
2020-11-18 11:35:25 <os-server><www-data><ACT> Application shutdown
2020-11-18 11:36:40 <os-server><www-data><ACT> Initialize common web application data
2020-11-18 11:36:40 <os-server><www-data><ACT> Connect to SCADA-Server “localhost”
2020-11-18 11:36:40 <os-server><www-data><ACT> Refresh the tables of the configuration database
2020-11-18 11:36:40 <os-server><www-data><ACT> Fill input channels properties
2020-11-18 11:36:40 <os-server><www-data><ACT> Fill output channels properties
2020-11-18 11:36:40 <os-server><www-data><ACT> Fill input channel statuses properties
2020-11-18 11:36:46 <os-server><www-data><EXC> Application error:
System.Web.Compilation.CompilationException (0x80004005): CS0103: The name `phrases’ does not exist in the current context
at System.Web.Compilation.AssemblyBuilder.BuildAssembly (System.Web.VirtualPath virtualPath, System.CodeDom.Compiler.CompilerParameters options) [0x00312] in <716e5fc6fa1b4b5db9a4701d451ead9c>:0
at System.Web.Compilation.AssemblyBuilder.BuildAssembly (System.Web.VirtualPath virtualPath) [0x00008] in <716e5fc6fa1b4b5db9a4701d451ead9c>:0
at System.Web.Compilation.BuildManager.GenerateAssembly (System.Web.Compilation.AssemblyBuilder abuilder, System.Web.Compilation.BuildProviderGroup group, System.Web.VirtualPath vp, System.Boolean debug) [0x00202] in <716e5fc6fa1b4b5db9a4701d451ead9c>:0
at System.Web.Compilation.BuildManager.BuildInner (System.Web.VirtualPath vp, System.Boolean debug) [0x00106] in <716e5fc6fa1b4b5db9a4701d451ead9c>:0
Page: http://localhost/scada/Error.aspx
Server Log
2020-11-18 10:03:01 <os-server><root><ACT> ScadaServerService 5.1.4.0 is started
2020-11-18 10:03:02 <os-server><root><ACT> Check the existence of the data directories is completed successfully
2020-11-18 10:03:02 <os-server><root><ACT> Check the existence of the configuration database files is completed successfully
2020-11-18 10:03:02 <os-server><root><ACT> Input channels are read from the configuration database. Active channel count: 5
2020-11-18 10:03:02 <os-server><root><ACT> Ouput channels are read from the configuration database
2020-11-18 10:03:02 <os-server><root><ACT> Users are read from the configuration database
2020-11-18 10:03:02 <os-server><root><ACT> Formulas are read from the configuration database
2020-11-18 10:03:06 <os-server><root><ACT> The formulas source code has been compiled
2020-11-18 10:03:06 <os-server><root><ACT> Connection listener is started
2020-11-18 10:03:06 <os-server><root><ACT> Start server
2020-11-18 10:03:06 <os-server><root><ACT> Current data are loaded
2020-11-18 10:03:13 <os-server><root><ACT> Connect to client 127.0.0.1
2020-11-18 10:03:13 <os-server><root><ACT> The user ScadaComm is successfully authenticated
2020-11-18 10:40:27 <os-server><root><ACT> Connect to client 127.0.0.1
2020-11-18 10:40:27 <os-server><root><ACT> The user ScadaWeb is successfully authenticated
2020-11-18 10:41:32 <os-server><root><ACT> Disconnect client 127.0.0.1
2020-11-18 11:20:18 <os-server><root><ACT> Connect to client 127.0.0.1
2020-11-18 11:20:18 <os-server><root><ACT> The user ScadaWeb is successfully authenticated
2020-11-18 11:20:20 <os-server><root><ACT> Check username and password for admin. Result: failed
2020-11-18 11:20:23 <os-server><root><ACT> Check username and password for admin. Result: failed
2020-11-18 11:20:27 <os-server><root><ACT> Check username and password for admin. Result: failed
2020-11-18 11:20:37 <os-server><root><ACT> Check username and password for admin. Result: failed
2020-11-18 11:20:43 <os-server><root><ACT> Check username and password for guest. Result: passed
2020-11-18 11:21:01 <os-server><root><ACT> Check username and password for admin. Result: failed
2020-11-18 11:21:07 <os-server><root><ACT> Check username and password for guest. Result: passed
2020-11-18 11:22:14 <os-server><root><ACT> Disconnect client 127.0.0.1
2020-11-18 11:36:40 <os-server><root><ACT> Connect to client 127.0.0.1
2020-11-18 11:36:40 <os-server><root><ACT> The user ScadaWeb is successfully authenticated
2020-11-18 11:37:40 <os-server><root><ACT> Disconnect client 127.0.0.1
——————————————————————————–November 18, 2020 at 2:22 pm #7571
Try editing the Login.aspx that is included in the AutoLogin plugin.
There should be<script type="text/javascript"> var phrases = <%= Scada.Web.WebUtils.DictionaryToJs("Scada.Web.WFrmLogin.Js") %>; </script>Test it on Windows first.
November 18, 2020 at 2:23 pm #7572
MikhailModeratorOr take the up to date Login.aspx from the web application and add
<script type="text/javascript" src="js/autologin.js"></script>November 18, 2020 at 2:26 pm #7573
MikhailModeratorI can fix and release the new version of AutoLogin plugin after the new version of Rapid SCADA is completed. Which is coming soon.
