Forum Home › Forums › Installation Issues › SCADA-Web Installation › Server is unavailable
- This topic has 38 replies, 6 voices, and was last updated 1 year, 8 months ago by
November 24, 2017 at 5:37 pm #2841
LPG57
ParticipantHello,
After migrating to Scada 5.4.1, I can’t log in on the Scada web page, get the message “Server is unavailable”.
I used the same user as I used with the old version (admin).
ScadaserverSVC log:
2017-11-22 22:21:50 <SERVER7><SYSTEM><ACT> ScadaServerService 5.1.0.2 is started
2017-11-22 22:21:50 <SERVER7><SYSTEM><ACT> Check the existence of the data directories is completed successfully
2017-11-22 22:21:50 <SERVER7><SYSTEM><ACT> Check the existence of the configuration database files is completed successfully
2017-11-22 22:21:50 <SERVER7><SYSTEM><ACT> Input channels are read from the configuration database. Active channel count: 43
2017-11-22 22:21:50 <SERVER7><SYSTEM><ACT> Ouput channels are read from the configuration database
2017-11-22 22:21:50 <SERVER7><SYSTEM><ACT> Users are read from the configuration database
2017-11-22 22:21:50 <SERVER7><SYSTEM><ACT> Formulas are read from the configuration database
2017-11-22 22:21:50 <SERVER7><SYSTEM><ACT> The formulas source code has been compiled
2017-11-22 22:21:50 <SERVER7><SYSTEM><ACT> Connection listener is started
2017-11-22 22:21:50 <SERVER7><SYSTEM><ACT> Start server
2017-11-22 22:21:51 <SERVER7><SYSTEM><ACT> Current data are loaded
2017-11-22 22:21:51 <SERVER7><SYSTEM><ACT> Connect to client 127.0.0.1
2017-11-22 22:21:51 <SERVER7><SYSTEM><ACT> The user ScadaComm is successfully authenticated
2017-11-22 22:22:03 <SERVER7><SYSTEM><ACT> Connect to client 127.0.0.1
2017-11-22 22:22:03 <SERVER7><SYSTEM><ACT> The user ScadaComm is successfully authenticated
2017-11-22 22:22:30 <SERVER7><SYSTEM><ACT> Connect to client 127.0.0.1
2017-11-22 22:22:30 <SERVER7><SYSTEM><ACT> Unsuccessful attempt to authenticate the user
2017-11-22 22:42:25 <SERVER7><SYSTEM><ACT> Disconnect client 127.0.0.1
2017-11-22 22:48:37 <SERVER7><SYSTEM><ACT> Connect to client 127.0.0.1
2017-11-22 22:48:37 <SERVER7><SYSTEM><ACT> Unsuccessful attempt to authenticate the user
2017-11-22 22:48:37 <SERVER7><SYSTEM><ACT> Disconnect client 127.0.0.1
2017-11-22 22:49:04 <SERVER7><SYSTEM><ACT> Connect to client 127.0.0.1
2017-11-22 22:49:04 <SERVER7><SYSTEM><ACT> Unsuccessful attempt to authenticate the user
2017-11-22 23:09:08 <SERVER7><SYSTEM><ACT> Connect to client 127.0.0.1
2017-11-22 23:09:08 <SERVER7><SYSTEM><ACT> Unsuccessful attempt to authenticate the user
2017-11-22 23:09:08 <SERVER7><SYSTEM><ACT> Disconnect client 127.0.0.1
2017-11-22 23:09:22 <SERVER7><SYSTEM><ACT> Connect to client 127.0.0.1
2017-11-22 23:09:22 <SERVER7><SYSTEM><ACT> Unsuccessful attempt to authenticate the user
2017-11-22 23:09:22 <SERVER7><SYSTEM><ACT> Disconnect client 127.0.0.1
2017-11-24 18:25:00 <SERVER7><SYSTEM><ACT> Connect to client 127.0.0.1
2017-11-24 18:25:00 <SERVER7><SYSTEM><ACT> Unsuccessful attempt to authenticate the user
2017-11-24 18:25:00 <SERVER7><SYSTEM><ACT> Disconnect client 127.0.0.1ScadaServerSvc.txt:
SCADA-Server
Started : 22/11/2017 22:21:50
Execution time : 1.20:12:49
State : normal
Version : 5.1.0.2Connected Clients (1)
1. 127.0.0.1; ScadaComm (Application); activity: 18:34:39ScadaWeb.log
2017-11-22 23:09:08 <SERVER7><DefaultAppPool><ACT> User information has been added. IP address: ::1. Session: 54ao1isfna1zamq3si5xtkqo
2017-11-22 23:09:22 <SERVER7><DefaultAppPool><ACT> Connect to SCADA-Server “localhost”
2017-11-22 23:09:22 <SERVER7><DefaultAppPool><ERR> User name or password is incorrect
2017-11-22 23:09:22 <SERVER7><DefaultAppPool><ACT> Disconnect from SCADA-Server
2017-11-22 23:09:22 <SERVER7><DefaultAppPool><EXC> Error refreshing the tables of the configuration database:
Scada.ScadaException: Unable to receive the configuration database modification time.
at Scada.Client.DataCache.RefreshBaseTables()
2017-11-22 23:09:22 <SERVER7><DefaultAppPool><ERR> Unable to connect to SCADA-Server. Try again.
2017-11-22 23:09:22 <SERVER7><DefaultAppPool><ERR> Unsuccessful login attempt: peder – Server is unavailable. IP address: ::1
2017-11-22 23:29:22 <SERVER7><DefaultAppPool><ACT> User information has been removed. IP address: ::1. Session: 54ao1isfna1zamq3si5xtkqo
2017-11-24 18:25:00 <SERVER7><DefaultAppPool><ACT> Connect to SCADA-Server “localhost”
2017-11-24 18:25:00 <SERVER7><DefaultAppPool><ERR> User name or password is incorrect
2017-11-24 18:25:00 <SERVER7><DefaultAppPool><ACT> Disconnect from SCADA-Server
2017-11-24 18:25:00 <SERVER7><DefaultAppPool><EXC> Error refreshing the tables of the configuration database:
2017-11-24 18:25:00 <SERVER7><DefaultAppPool><ACT> User information has been added. IP address: 83.142.103.76. Session: lxw0v20243tol44phkjh34ul
2017-11-24 18:25:10 <SERVER7><DefaultAppPool><ERR> Unable to connect to SCADA-Server. Try again.
2017-11-24 18:25:10 <SERVER7><DefaultAppPool><EXC> Error refreshing the tables of the configuration database:
2017-11-24 18:25:10 <SERVER7><DefaultAppPool><ERR> Unsuccessful login attempt: admin – Server is unavailable. IP address: 83.142.103.76November 25, 2017 at 11:29 am #2842Mikhail
ModeratorHi,
Please open C:\SCADA\ScadaWeb\config\WebSettings.xml in a text editor and check CommSettings section. These are the connection parameters for the web app. Can you provide them here?
November 25, 2017 at 11:30 am #2843Mikhail
ModeratorAlso check CPU load of ScadaServerSvc.exe.
November 25, 2017 at 12:40 pm #2844LPG57
ParticipantHello Mikhail,
The CPU load of ScadaServerSvc.exe is currently 0
and here is the WebSettings.xml:<?xml version=”1.0″ encoding=”utf-8″ ?>
– <WebSettings>
<Param name=”SrezRefrFreq” value=”5″ descr=”Values refresh frequency, sec” />
<Param name=”EventRefrFreq” value=”5″ descr=”Events refresh frequency, sec” />
<Param name=”EventCnt” value=”50″ descr=”Display events count” />
<Param name=”EventFltr” value=”true” descr=”Set ‘View’ events filter by default” />
<Param name=”DiagBreak” value=”90″ descr=”Distance between points on the diagramm to make a break, sec” />
<Param name=”CmdEnabled” value=”true” descr=”Enable commands” />
<Param name=”SimpleCmd” value=”false” descr=”Simple commands sending” />
<Param name=”RemEnabled” value=”false” descr=”Enable to remember logged on user” />
</WebSettings>November 25, 2017 at 12:45 pm #2845LPG57
Participantand here is the CommSettings.xml
– <CommSettings>
<Param name=”ServerHost” value=”localhost” descr=”SCADA-Server host or IP address” />
<Param name=”ServerPort” value=”10000″ descr=”SCADA-Server TCP port number” />
<Param name=”ServerUser” value=”ScadaWeb” descr=”User name for the connection” />
<Param name=”ServerPwd” value=”12345″ descr=”User password for the connection” />
<Param name=”ServerTimeout” value=”10000″ descr=”Response timeout, ms” />
</CommSettings>I tried also with user “ScadaWeb”, but the result was the same
November 26, 2017 at 9:23 am #2849Mikhail
ModeratorThe format of the WebSettings.xml file was changed. You should take the new one from the distributive.
You don’t need CommSettings.xml for the web app no more.November 26, 2017 at 2:58 pm #2856LPG57
ParticipantFollowing the instructions above solved the login problem – thanks’
However, when logged in the following message appear:
“The requested view does not exist or you have insufficient rights to access it.”I can open the tables in the table editor.
November 26, 2017 at 4:25 pm #2857LPG57
ParticipantI solved the issue above, found out that there were differences in the Interface table between the old and new version.
Now I only wonders how the “Rights” table “Interface Objects” field is populated? In the drop down list, there is only the demo objects, not the tables I built?
November 27, 2017 at 9:48 am #2858LPG57
ParticipantMikhail
The issue with the rights table is solve, but now I have a new problem:
When connecting with the web station, it works OK while doing it directly on the server itself, but when doing it from a PC outside the domain, I can login, but the tables are not updated with data and the message “Error updating current data” appear. After 10 secs, I’m thrown out.
Login performed 10:21 was on localhost and succeeded, login performed 10:23 was from a remote PC and failed.
ScadaWeb.log
2017-11-27 10:21:54 <SERVER7><DefaultAppPool><ACT> Request SCADA-Server state
2017-11-27 10:21:54 <SERVER7><DefaultAppPool><ACT> Disconnect from SCADA-Server
2017-11-27 10:21:54 <SERVER7><DefaultAppPool><ACT> Connect to SCADA-Server “localhost”
2017-11-27 10:21:54 <SERVER7><DefaultAppPool><ACT> User information has been added. IP address: ::1. Session: b3knixrzaedaicjuaoku3wml
2017-11-27 10:21:57 <SERVER7><DefaultAppPool><ACT> Login: admin (Administrator). IP address: ::1
2017-11-27 10:21:57 <SERVER7><DefaultAppPool><ACT> User information has been updated. IP address: ::1. Session: b3knixrzaedaicjuaoku3wml
2017-11-27 10:22:27 <SERVER7><DefaultAppPool><ACT> Logout: admin. IP address: ::1
2017-11-27 10:23:22 <SERVER7><DefaultAppPool><ACT> Request SCADA-Server state
2017-11-27 10:23:22 <SERVER7><DefaultAppPool><ACT> Login: admin (Administrator). IP address: 199.64.75.186
2017-11-27 10:23:22 <SERVER7><DefaultAppPool><ACT> User information has been updated. IP address: 199.64.75.186. Session: lxw0v20243tol44phkjh34ulScadaServerSvc.log
2017-11-27 10:21:54 <SERVER7><SYSTEM><ACT> Connect to client 127.0.0.1
2017-11-27 10:21:54 <SERVER7><SYSTEM><ACT> The user ScadaWeb is successfully authenticated
2017-11-27 10:21:57 <SERVER7><SYSTEM><ACT> Check user admin name and password. Result: passed
2017-11-27 10:23:22 <SERVER7><SYSTEM><ACT> Check user admin name and password. Result: passedNovember 27, 2017 at 4:03 pm #2860Mikhail
ModeratorHi,
Does it work from another PC in the same network?
Please press F12 in a browser and provide logs (or screenshots) from the Console and Network tabs.November 28, 2017 at 9:32 pm #2880LPG57
ParticipantHello,
If I’m connect using http://servername7scada from another computer within the domain, it works OK. But if I’m from the same computer use the external https://domainname/scada, it doesn’t work.
November 29, 2017 at 1:54 pm #2888November 29, 2017 at 9:02 pm #2897LPG57
ParticipantThere was already a certificate for port 443 for this web site, so when creating another one, I couldn’t log on remotely anymore. (Running SBS 2011)
November 30, 2017 at 6:25 pm #2898Mikhail
ModeratorHTTPS is more tricky. To solve this issue, a remote connection is required – this is a commercial service.
November 30, 2017 at 6:26 pm #2899Mikhail
ModeratorDoes https://localhost/ work?
