Scheme Symbols/IMG
Forum Home Forums Understanding the Software Scheme Symbols/IMG
Viewing 15 posts - 1 through 15 (of 20 total)
  • #1009
    Washu Hakubi
    When i open the Scheme Editor there is no IMG available to use.
    Is there a free HMI/Scada free IMG repository available?
    How does Dinamic IMG works and what is the format for it?
    How can i make new IMGs? Is it possible to use Inkscape-Sage?
    For example, is it possible to make a gauge that the pointer changes according to the input of a tag?
    #1010
    Not yet. I usually look for images in Google Images
    It shows an image depending on Input channel value and its Conditions property.
    You can use PNG and JPG image formats.
    Any image editor. I use Microsoft Visio. Inkscape is good, but you should convert images to PNG or JPG.
    For now you should create a set of images with different levels and use Dynamic picture component. In the future such components will be developed.
    #1015
    Washu Hakubi
    I believe i read somewhere that a new Scheme system is been developed that don’t use Silverlight to be possible to open em on mobile devices.
    Is there a time for when it will be available?
    Will it use SVG format for dynamic img?
    Will it have a special library to support different sizes of screen, like BootStrap, or will it use pure CSS3?
    Right now my client really want those Gauges and other animated graphics so i will try to make em on SVG in a custom webpage, but would be really good if it was supported by default.
    #1018
    The beta version of the new schemes will be released in the summer 2016. In the first time it will support the existing format of schemes. SVG will be supported a bit later. Bootstrap is used. New components such as gauges will be added in the same time as SVG.
    Thank you for your patience 🙂
    In Chrome:
    1
    #2652
    QuimV
    Is there any way to use svg in dynamic picture?
    I’m trying to create a tank that fills up dynamically.
    • This reply was modified 8 years, 9 months ago by QuimV.
    #2654
    Yes, you can add svg to a scheme. You should create a set of images with different level of liquid and change a picture according to a value. We are going to create ready to use controls for this purpose.
    #2655
    QuimV
    Thank you for your quick response.
    Is there any availability schedule for this functionality?
    #2656
    This features will be added in the plan as soon as we can. This is a major task.
    #2657
    To receive notifications about new features, subscribe our Facebook page.
    #3430
    catcute
    Hi,is svg image adready support in scheme? And how can i use it? Thanks!
    #3432
    catcute
    Hi, I’ve just find out the answer!
    #3436
    OK 🙂
    #7563
    dinop
    I am trying Extra Scheme component plugin and I want to try house gauge works.
    My question is: is it possible to make a gauge that the pointer changes according to the input of a tag?
    If this is possible I would also like to know how.
    Thanks.
    #7566
    You should set the Input channel property of the gauge component to show channel value. If something goes wrong, please post links to screenshots of the existing settings.
    #7567
    dinop
    Hello Mikhail,
    here is a screenshot because I do not understand how to make it. With levels bars I did not have any problems.
    https://ibb.co/6NVGHNb
