New Rapid SCADA 5.7.0 Beta
Forum Home › Forums › Uncategorized Issues › New Rapid SCADA 5.7.0 Beta
Viewing 15 posts - 1 through 15 (of 23 total)
  • #5371
    Download links for Rapid SCADA 5.7.0 Beta:
    Windows version
    Linux version
    Video overview
    What’s new:
    – Completely new Administrator
    – Completely new Table Editor
    – Agent is included in the installation package
    – Project approach of configuration
    Server service, Communicator service and Webstation are identical to version 5.6.1 and stable.
    Bug reports and suggestions are welcome.
    • This topic was modified 7 years, 4 months ago by Mikhail.
    #5394
    JD
    Hello, with this beta version is it possible to use names instead of signal number for the channel objects? The reason is we are using an OPC and when we add a new tag and would like to group it with existing ones, signal value of other tags shift by one. As result, the channel objects refer to old signal values.
    #5396
    This feature is going to be be implemented in a one of future versions, but not in this beta. If your company able to sponsor this feature, it can appear faster. In any case, I hope we will do it.
    #5449
    jmartins
    Hi Mikahil.
    I have a site developed under RapidScada 5.6.0, running fine until today.
    Just upgraded to the 5.7.0 beta: the website seems to be running ok with my previous project, but cannot find any of the existing configuration and data on the new Administrator.
    ¿Is there any tutorial on how to migrate or “import” all the old work previously done into a new project?
    Regards,
    Juan Carlos.
    #5455
    Hi Juan,
    To upgrade:
    1. Create a new empty project in the new Administrator.
    2. Make sure that the existing configuration is deployed to your server and works well.
    3. Download the existing configuration into the new project by Administrator.
    #5475
    jmartins
    Hi Mikhail.
    I did that way and worked.
    Thank you!
    #5568
    Horacio
    Hello Mikhail,
    I installed version 5.7.0. Windows settings are as indicated.
    However, the installer issued errors.
    Despite them, the version seems to work well and I could successfully follow all the steps of the video example/demo.
    Now I need to migrate the database configuration I was using with version 5.6.1.
    Do I have to do it using the former procedure “Migrate Configuration to New Server”? Or instead,
    Use the Upload and Download feature provided in version 5.0.7?
    I saw the indications you gave to community member “jmartins”.
    Could you please explain:
    “3. Download the existing configuration into the new project by Administrator.”
    Thank you very much.
    Best regards
    Horacio
    #5577
    Joao
    Hi, how do i organize Channels by Objects?
    #5976
    Use filter of a table.
    #5983
    Joao
    Im sorry, I didn’t express myself correctly.
    I mean that I didnt found the button that group channels by objects.
    Old version of administrator:
    https://imgur.com/a/EcDS0VV
    #5984
    Yes, I understand. This button is removed. Instead of this, you can use a filter of the Input channels table to filter the records by an object.
    Why grouping by devices is not enough for you? What is the specifics of your system?
    #5988
    Joao
    Hi, because I have 15 different places, and some of this places have more than 1 PLC. I builded all the structure agrouping all PLCs, and local variables by objects, each object represent a place.
    #5989
    I see. Did you find the filter feature?
    #5990
    Joao
    Yes, I think that it solve my problem.
