Forum Home › Forums › Uncategorized Issues › New Rapid SCADA 5.7.0 Beta
- This topic has 22 replies, 6 voices, and was last updated 6 years, 2 months ago by
April 26, 2019 at 7:03 am #5371
MikhailModeratorDownload links for Rapid SCADA 5.7.0 Beta:
Windows version
Linux versionWhat’s new:
– Completely new Administrator
– Completely new Table Editor
– Agent is included in the installation package
– Project approach of configurationServer service, Communicator service and Webstation are identical to version 5.6.1 and stable.
Bug reports and suggestions are welcome.
This topic was modified 6 years, 10 months ago by
May 6, 2019 at 1:38 pm #5394JD
ParticipantHello, with this beta version is it possible to use names instead of signal number for the channel objects? The reason is we are using an OPC and when we add a new tag and would like to group it with existing ones, signal value of other tags shift by one. As result, the channel objects refer to old signal values.
May 6, 2019 at 6:22 pm #5396
This feature is going to be be implemented in a one of future versions, but not in this beta. If your company able to sponsor this feature, it can appear faster. In any case, I hope we will do it.May 14, 2019 at 4:38 pm #5449
jmartinsParticipantHi Mikahil.
I have a site developed under RapidScada 5.6.0, running fine until today.
Just upgraded to the 5.7.0 beta: the website seems to be running ok with my previous project, but cannot find any of the existing configuration and data on the new Administrator.
¿Is there any tutorial on how to migrate or “import” all the old work previously done into a new project?Regards,
Juan Carlos.May 15, 2019 at 4:06 pm #5455
MikhailModeratorHi Juan,
To upgrade:
1. Create a new empty project in the new Administrator.
2. Make sure that the existing configuration is deployed to your server and works well.
3. Download the existing configuration into the new project by Administrator.May 21, 2019 at 5:59 pm #5475
jmartinsParticipantHi Mikhail.
I did that way and worked.
Thank you!June 18, 2019 at 4:55 pm #5568
HoracioParticipantHello Mikhail,
I installed version 5.7.0. Windows settings are as indicated.
However, the installer issued errors.
Despite them, the version seems to work well and I could successfully follow all the steps of the video example/demo.Now I need to migrate the database configuration I was using with version 5.6.1.
Do I have to do it using the former procedure “Migrate Configuration to New Server”? Or instead,
Use the Upload and Download feature provided in version 5.0.7?I saw the indications you gave to community member “jmartins”.
Could you please explain:
“3. Download the existing configuration into the new project by Administrator.”Thank you very much.
Best regards
HoracioJune 19, 2019 at 1:54 pm #5577
September 24, 2019 at 6:13 pm #5973Joao
ParticipantHi, how do i organize Channels by Objects?
September 25, 2019 at 2:28 pm #5976
Use filter of a table.
September 30, 2019 at 1:51 pm #5983Joao
ParticipantIm sorry, I didn’t express myself correctly.
I mean that I didnt found the button that group channels by objects.Old version of administrator:
https://imgur.com/a/EcDS0VVOctober 1, 2019 at 1:13 pm #5984
MikhailModeratorYes, I understand. This button is removed. Instead of this, you can use a filter of the Input channels table to filter the records by an object.
Why grouping by devices is not enough for you? What is the specifics of your system?
October 3, 2019 at 12:11 pm #5988Joao
ParticipantHi, because I have 15 different places, and some of this places have more than 1 PLC. I builded all the structure agrouping all PLCs, and local variables by objects, each object represent a place.
October 4, 2019 at 9:00 am #5989
MikhailModeratorI see. Did you find the filter feature?
October 4, 2019 at 12:50 pm #5990Joao
ParticipantYes, I think that it solve my problem.
