MQTT in-depth Installation Help
Forum Home Forums Communicating with Devices MQTT in-depth Installation Help
Viewing 15 posts - 1 through 15 (of 26 total)
  • #6103
    wonderwareguru
    Greetings, Happy Thanksgiving
    I am new to RapidScada. Before you roll your eyes, I’m sorry to come off as a novice. Can someone please provide a step by step installation and setup of the MQTT plugin. If possible a video example like the setup video of Modbus on youtube.
    I looked at the rapidscada’s doc section, github’s description and nothing shows where to place kpmqtt.dll, kpmqtt_config, job, jint.dll. I gather so far, ScadaComm directory. kpmqtt.dll —> KP? kpmqtt_config —> config? Where do the job & jint files go???
    Can someone please hold my candyass hand? I would really appreciate a working example of setting up MQTT and a simple subscribe / publish to a broker; and printing it to dynamic text.
    I’ve been using Mango Automation, Wonderware and would like to switch to RapidScada. Thanks alot.
    Humbly yours
    #6117
    greenfoxx
    Hi!
    We have posted a brief instruction in English https://github.com/RapidScada/scada-community/blob/master/Drivers/KpMqtt/README-EN.md recently. Maybe you will find it useful. In the manual we can get an example of configuring KpMQTT_Config.xml
    You need to place
    1.kpmqtt.dll file in the folder C:\SCADA\ScadaComm\KP
    2.kpmqtt_config file in the folder C:\SCADA\Projects\TestProject\Instances\Default\ScadaComm\Config
    3.jint.dll file in the folder C:\SCADA\ScadaComm\KP
    4.file job.js in the folder C:\SCADA\ScadaComm\KP
    This driver was developed by our community, and at the moment the Rapid SCADA team has begun to finalize the driver.
    • This reply was modified 6 years, 1 month ago by Mikhail.
    #6121
    wonderwareguru
    Hi GreenFoxx,
    I appreciate your reply. I moved the files to their appropriate directories; however, I’m still trying to figure out how set everything up in Rapdiscada.
    The following is a good start:
    unfortunately, it still doesn’t help setup rapidscada. I can create a communication line… but the instructions say to link the mqtt configuration file. How is that done?
    I would really appreciate a step by step setup of rapidscada with MQTT. It’s easy for the developer that designed it, but not the end user.
    Thank you
    #6123
    chriskkelly
    I am having similar issues where should i place MQTTCore and Properties folders for mqtt installation?
    #6127
    greenfoxx
    Hi!
    Brief instruction
    1. Make sure that the library is available in the driver list.
    Communicator-> Drivers.
    Here you will see lists of available drivers. The KpMqtt.dll should be on the list.
    2. Add device type to the Dictionaries.
    Configuration Database->Dictionaries->Devices Type
    For example:
    ID Name DLL Filename Description
    (Last ID)* MQTT KpMqtt.dll MQTT driver
    3. Add Communication line.
    Configuration Database->System->Communication line
    For example:
    Number Name Description
    21 MQTT MQTT
    4. Add devices.
    Configuration Database->System->Devices
    For example
    Number Name Device Type Communication line Description
    42 MQTTtest MQTT MQTT MQTTtest
    Other fields are empty
    5. Add input channel.
    Configuration Database->System->Input channels
    Before to this, you need to update data. Stand on the ‘input channel’, right-click and click on the ‘Refresh’ button
    For example for [42] MQTTtest (here name devices)
    Number Active Name Channel Type Object Device Signal
    600 V mqttparam1 Calculate Real Enterprise MQTTtest 1
    601 V Mqttparam2 Calculate Real Enterprise MQTTtest 2
    602 V Mqttparam3 Calculate Real Enterprise MQTTtest 3
    * Number, Name must be the same like in configuration file
    6. Upload Configuration
    7. Configure MQTT
    Instances->Communicator->Communication Line
    Stand on the ‘Communication Line’, right-click and click on the ‘Import’ button. Select communication line [21]MQTT (for example)
    Line Parameters contains 3 tabs.
    1. Main Parameters
    Here you can see the name and number communication line. In our example, number 21
    2. Custom Parameters
    Can be empty.
    3. Request Parameters
    Add following data:
    In our example:
    Number: 42 (number device)
    Driver: KpMqtt.dll
    Command line: KpMQTT_Config.xml
    8. Save and upload configuration
    9. Start line (Stand on the [21]MQTTest, right-click and click on the ‘Start line’ button)
    10. If everything is configured correctly, on the tab
    Communication line->[21]MQTT->[42]MQTTtest you can see data. In our Example.
    #6129
    chriskkelly
    cheers, still confused where two place the two directories MQTTCore and Properties
    #6130
    wonderwareguru
    Thanks a lot for your time GreenFoxx… I’ll play around with your guide tonight and reply back.
    Thank you again
    #6182
    hauvysieu
    Hello, thanks you for time GreenFoxx! I had did all steps that you guided but still can not finish my project.
    It said :
    State : error.
    No device tags
    No archive data
    No events
    No commands
    ๐Ÿ™
    Idk how to do now. Please give me a hand.
    Best regards!
    #6183
    greenfoxx
    Hi!
    We’ve just added a new video https://www.youtube.com/watch?v=QTcimIik6uU&feature=youtu.be
    Perhaps it will be useful to you
    #6196
    lucianod6
    ok now i can do both the PUB and the SUB, this is my video .. congratulations for this nice job done by you
    https://youtu.be/f05fw-YLxc4
    • This reply was modified 6 years ago by lucianod6.
    #6201
    Thanks a lot for the video!
    #6233
    ALnaluk
    http://picture.in.th/id/a0105e8add43cb7d51965ee19b630112
    please help me
    • This reply was modified 6 years ago by ALnaluk.
    #6238
    greenfoxx
    Hi!
    Could you please check Configuration Database->Dictionaries->Device Type column DLL Filename
    You need to write KpMqtt.dll (pay attention to the case of letters)
    Also could you please check Line Parameters ->Request Sequence text DLL.
    In your picture KpMQTT (MQTT in uppercase)
    • This reply was modified 6 years ago by greenfoxx.
    #6242
    The message in the screenshot is not a error. You should check communication line log.
    Where did you download KpMqtt.dll from?
    #6248
    ALnaluk
    when i use “KpMqtt:v5.0.0
    @2mik 2mik released this on 11 Sep ยท 10 commits to master since this release
    KpMqtt: rename KpMqttConfig1”
    i have this error “Error getting device interface type from the library KpMqtt.dll: An attempt was made to load an assembly from a network location which would have caused the assembly to be sandboxed in previous versions of the .NET Framework. This release of the .NET Framework does not enable CAS policy by default, so this load may be dangerous. If this load is not intended to sandbox the assembly, please enable the loadFromRemoteSources switch. See http://go.microsoft.com/fwlink/?LinkId=155569 for more information.”
