Mimic(мнемосхема)
Forum Home › Forums › Installation Issues › SCADA-Web Installation › Mimic(мнемосхема)
Viewing 15 posts - 1 through 15 (of 38 total)
  • #660
    Evgen
    Hello!
    I am interested in the ability to mimic the output through the Rapid SCADA. As they draw and how to display data from the controller to mimic?
    Thank you in advance!
    #661
    As I understand, you’d like to emulate incoming data? There are 2 way to do it:
    1. Send values from Generator page of SCADA-Server.
    2. Install Matrikon OPC Simulation Server and establish a connection with it.
    If you mean something else, please let me know.
    #667
    Evgen
    I connected the controller KODESIS IF amplifier and output the data in the table.
    As in this figure
    https://yadi.sk/i/0BLIJ0gIkGGtH
    And I need a beautiful picture.
    Here are some here.
    https://yadi.sk/i/nZfjXhxbkGH7N
    How to do it?
    PS I write in Russian and use a translator program on this, you can not understand me.
    #668
    Evgen
    KODESIS IF this incorrect translation, the original of a CodeSys OPC
    #671
    First of all, with help of SCADA-Administrator and SCADA-Communicator configure data obtaining from OPC server: http://rapidscada.org/connecting-devices-using-opc-standard/
    Then open SCADA-Scheme Editor and create a beautiful scheme. Bind controls to the input channels that were created in the first step. Open SCADA-Web Configurator application and add your scheme.
    Follow up questions are welcome.
    #672
    Evgen
    I have set up data acquisition with opc server !!!!
    here’s how to draw diagrams in the editor? I have only to insert the inscription there !!! No lines or shapes.
    and there vozmozkost paste the finished drawing to add controls?
    #673
    Create a background image with any graphical editor you prefer. Then open SCADA-Scheme Editor, add the background and add dynamic elements.
    #678
    Evgen
    Michael thanks for the tips.
    I now have a question, and there are other interfaces RapidSKADA. Manager wants different options to choose from. or if there is a way to change the interface.
    #680
    Please provide more information about interfaces that you need. Do you mean styles or something else?
    #681
    You can call me and ask common questions.
    #682
    Evgen
    Yes you are right I’m interested in styles.
    #683
    Evgen
    Unfortunately, I can not call you at work since.
    #684
    Evgen
    I must place on the Welcome page logo where I work page now looks like this
    #685
    Find images here C:\SCADA\ScadaWeb\images and replace the appropriate image.
    Also you may edit *.aspx files if you are able to use HTML.
    #704
    Evgen
    How you can contact? I have a question and I need a more detailed explanation.
    And thanks again for all the advice you gave. Very helpful.
